Moving antenna location
I currently have my antenna attached to a fence post so its only about 2 meters off the ground but I am looking into whether it would be worthwhile moving the antenna onto the roof of my 2 story house ?
What info would I need to submit to the forum for you experts to make an informed answer on whether its worth the effort please?
Thanks in advance
If going up on the roof also implies a better view around with less obstructions ( I suspect in this case your own house is an obstruction) then that would benefit your reception.
If you are already functional at the fence post, what are the chances that you can raise the antenna at the same fence post location? If you put something together that can be raised and lowered for service and storm wind protection it would keep you off the roof and the complications that involves.
Give the attic a try if you don’t want to mount it on the roof.
Probably better than the post you have now.
So, where is this fence post? Is it on the edge of an open field or next to your house, barn or wooded lot?
That’s an AI generated reply if ever I’ve seen one
No artificial intelligence here. My chip set was manufactured during the Korean war.
The one above yours which I flagged and was not giving any more airtime by quoting it because it’s from a person promoting tea.
That’s why it’s barely relevant and took 23 days to post it while the new user has only been here for minutes
You can do that easily?? :astonished:
Yes, a taller is always better, first and foremost. Antenna-wise, from .5 watt to 2k.
Sorry to quibble, but taller is almost always better.
As others have said, if it moves you to a place where there are more obstructions (say, moving from an open field to being surrounded by tall buildings), then it’s not beneficial. Most likely it’s better, unless the fence post is uphill from the house.
:grinning:
Correct! “Taller” is always better.
Its about 20ft from the house
Yes, your house is itself almost certainly an impediment to range. Moving the antenna to your attic or roof is likely to greatly increase your reception. If you have any chimneys or other obstructions, you’ll want it above those, as well.
How about adding a stackable antenna mast to the fence post or a Rohn-25 apex section positioned next to the fence post with the antenna mast system growing up out of the apex tower section?
This is my first time chatting on this site. Please tell me. Recently, I moved the antenna from the city center, where there are many multi-storey buildings, to the outskirts of the city, where the view of the horizon is much wider and even the airport site is visible. I have a desire to order another receiver and install it on the roof of a suburban area in a mountainous area 100 km from the city. Question: Will it be possible to combine my two receivers in my account?
Yes you can have multiple sites in one account but they will have their own centerpoint. So that will remain apart but the results will be combined. I have currently 19 sites in one account
This topic was automatically closed 365 days after the last reply. New replies are no longer allowed.
