as we get only mlat positions back from flightaware where our site is used for mlat - we will have less aircrafts we get positions back from now on?
true?
Before the changes I had round about 120000 mlat positions a day. Yesterday and today it will only around 45000.
If I compare this with a station 33km far from me that still have the same count of mlat positions.
As of this morning, after a reboot, piaware isn’t starting up MLAT at all for me. Is this related? It seems like the server is never requesting it so it doesn’t get enabled. Site 15021 if that helps.
This is why you don’t run development versions of piaware on sites you care about. You provided a GPS location once; now you must always provide a GPS location. This is a server-side issue that I need to get fixed before the development version is ready for use.
(If you’re never run gpsd on that hardware, let me know and I’ll dig further)
There are some internal tools but nothing suitable for general consumption at the moment. It might be nice to have a toggle that shows you the regions that you’re in on the site page or something like that.
I have plugged a GPS receiver into there before, causing gpsd to come up. Plugged it back in just now, and the mlat client started back up, so the diagnosis seems spot on, thanks.
Just trying to report an issue I noticed, wasn’t trying to cause you headache on the server side.
It seems like I haven’t had a large drop in the number of MLAT synchronized stations but I still saw a big MLAT drop after the server rebalance, assuming I’m recalling correctly before the change of around 100 stations. Does anyone know what might explain this?
The number of synchronized receivers is mostly irrelevant since it is a maximum, not a total. As above, you are probably in a different set of regions to before the rebalancing.
