Hi All,
Sorry if this has been covered before I have been running a rtl-sdr usb and I got my antenna today and it came with a microADSB do I need to install drivers for it to work with piaware or will it work out of the box.
cheers
Sean
Micro ADSB is receiver in it’s own right - may no need the Pi - does it have ethernet connections etc.
Hi Peter,
thanks for your reply it is a usb dongle with and antenna output on it you can get them at www.microADSB.com
have not been able to get it to work yet.
cheers
Sean
Gotcha
The MicroADSB dongle still is a self contained receiver
That means you can’t run DUMP1090 like we do for an R820T dongle - where dump 1090 does the decode.
I suspect the USB port looks like USB serial port adaptor presenting an analog stream of info at 19.2kb/s or something, which then needs something to manage into a map display / something that can de uploaded.
Hi Peter,
I am doing a bit of playing around with it see what I can come up with.
I need to make a usb port a serial port and it should work.
thanks for the reply.
Cheers
Sean
I have problems to install microadsb in PI
i can help!!!
tks
Rodrigo
