I want to cut down the little whip antenna that came with the dongle to 68 mm. I’m assuming I should measure between the tip and the base, where it connects to the feed line. That would include the brass base that the antenna screws onto, i.e., everything included between the arrows in the picture. Is that correct?
Does it really have the copper braid hanging around like that in the base? Not great… If you’re concerned about the last few mm you should add the part that is leaving the shieling too but it’s all pretty low-tech to me…
/paul
It seems like there is much room for improvement with the “ground array” copper shielding snakepit that is jammed in the bottom there. I’m not an expert, but perhaps someone could comment on the best way to improve that situation, which might also improve the reception of the stock antenna.
There’s actually a small metal disk with a magnet that sits below the shielding braid. I like the description “snakepit” - just what it looks like. I suspect the disk contacts the braid in its own feeble way and forms the ground plane.
