Just an update on some tweaks I have made that have helped squeeze out a bit more performance…
Remounted my antenna and it is now roughly 2-1/2ft higher.
The remount of the antenna required a longer cable run, so I switched from 25ft KMR240 to 35ft KMR400. The KMR400 is definitely harder to work with, but despite the extra 10ft of KMR400, I was able to reduce my attenuation by about 0.5dB (per the supplied specs – I didn’t actually measure myself).
I swapped out the light blue flight aware filter for a 1090 MHz cavity filter and a 978 MHz cavity filter.
I changed the order of inline hardware, swapped out the FlightAware SDRs for Nooelec Smartee v2’s and added Nooelec LaNA’s. The signal path now looks like this:
Antenna > KMR400 (35ft) > ZAPD-21 Splitter > Cavity filter > LNA > SDR
These changes yielded a slight uptick in plane counts, but a big increase in positions reported. Early results show I now get over 1.2 million positions with my best day so far being 1.34 million positions. I think the biggest help has been the cavity filters. My RF environment is much cleaner. Now, if I could just move those mountains out of the way…
