MapFlightEX Satellite with Boundaries Base Layer
Hi,
Using the FlightAware web app you can select the base layer as “Satellite with Boundaries”. Is it possible for the MapFlightEx to return an image using the same base layer instead of the standard blue?
In FlightXML only the single base layer is offered.
Using the lat-lon data from DecodeRoute or GetLastTrack could be used with an external mapping solution if more custom maps are desired.
