I am using the java program that is provided. I have an api key and a username and I have used those in the code I copied and pasted. I have also complete all the necessary imports. When I run the code it prints out the first line “Print Enroute to Aircraft” and then throws the following error:
Exception in thread “main” com.sun.xml.internal.ws.client.ClientTransportException: The server sent HTTP status code 401: Authorization Required
The account with the api key I am trying to use is different from the account I am logged into now. I’m not sure what the error means, but could that cause an issue?
Thanks for your help!
