https://flightxml.flightaware.com/json/FlightXML3/FlightInfoStatus
When I call this endpoint with the proper airline icao and flight number I get an inconsistent response where sometimes it will show an actual_departure_time
key and sometimes the key doesn’t even show up.
Is there a reason for this? Couldn’t you guys add a default value so that the API is consistent?
Also there are a bunch of fields that don’t always appear in the response (i.e codeshares
Is this a bug? I feel like you should be consistent and return the same params every time (just set a null value to the ones with no information)
If the flight has not departed yet, then actual_departure_time
will not be present. Similarly, if there are no known codeshares for that flight, then it will be absent.
Those fields are noted in the FlightXML3 documentation with ?
character suffix as being optional: FlightXML3 Web Services
