See the list below of issues
[2015-07-18 20:51 EDT] no ADS-B data program seen listening on port 30005 for 1 seconds, next check in 60s
[2015-07-18 20:51 EDT] multilateration support enabled (use piaware-config to disable)
[2015-07-18 20:51 EDT] multilateration data requested, enabling mlat client
[2015-07-18 20:51 EDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2015-07-18 20:51 EDT] 0 msgs recv’d from the ADS-B data program; 0 msgs sent to FlightAware
[2015-07-18 20:52 EDT] no ADS-B data program seen listening on port 30005 for 61 seconds, next check in 60s
[2015-07-18 20:52 EDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2015-07-18 20:53 EDT] no ADS-B data program seen listening on port 30005 for 121 seconds, next check in 60s
[2015-07-18 20:53 EDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
[2015-07-18 20:53 EDT] piaware (process 2754) is shutting down because it received a shutdown signal (SIGTERM) from the system…
[2015-07-18 20:53 EDT] multilateration data no longer required, disabling mlat client
[2015-07-18 20:53 EDT] piaware (process 2754) is exiting…
[2015-07-18 20:53 EDT] autoUpdate in adept config is enabled, allowing update
[2015-07-18 20:53 EDT] manualUpdate in adept config is enabled, allowing update
[2015-07-18 20:53 EDT] multilateration support enabled (use piaware-config to disable)
[2015-07-18 20:53 EDT] no ADS-B data program seen listening on port 30005 for 1 seconds, next check in 60s
[2015-07-18 20:53 EDT] multilateration data requested, enabling mlat client
[2015-07-18 20:54 EDT] 0 msgs recv’d from the ADS-B data program; 0 msgs sent to FlightAware
[2015-07-18 20:54 EDT] no ADS-B data program seen listening on port 30005 for 61 seconds, next check in 60s
[2015-07-18 20:54 EDT] no ADS-B data program is serving on port 30005, not starting multilateration client yet
I did get it to work. And is reporting data… But have lost live data the map wont open
Dump1090-mutability installs lighttb to display the data, since the built in webserver in dump1090 can cause the dump1090 to crash (be crashable)
