I downloaded the file to my Laptop then sent it to my RPI, same error.
I extracted the file(untared and unzip) on my laptop then sent to my RPI and it worked.
I must be missing some gzip or tar files on the RPI.
Thanks.
Jon
Thanks.
Jon
hm⌠tar is available in all installations, wonder whatâs going wrong on your device.
But anyways if you have a workaroundâŚ
But thereâs already something wrong with your download. tried it with my link above and it works with the correct size:
sudo wget https://github.com/wiedehopf/airspy-conf/raw/master/2.1RC/airspy_adsb-linux-arm64.tgz
--2021-08-30 21:10:33-- https://github.com/wiedehopf/airspy-conf/raw/master/2.1RC/airspy_adsb-linux-arm64.tgz
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://raw.githubusercontent.com/wiedehopf/airspy-conf/master/2.1RC/airspy_adsb-linux-arm64.tgz [following]
--2021-08-30 21:10:34-- https://raw.githubusercontent.com/wiedehopf/airspy-conf/master/2.1RC/airspy_adsb-linux-arm64.tgz
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.108.133, 185.199.110.133, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.108.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 39735 (39K) [application/octet-stream]
Saving to: âairspy_adsb-linux-arm64.tgzâ
airspy_adsb-linux-arm64.tgz 100%[==========================================================>] 38.80K --.-KB/s in 0.1s
2021-08-30 21:10:34 (356 KB/s) - âairspy_adsb-linux-arm64.tgzâ saved [39735/39735]
Your download above was 126.53k, so this is already incorrect
Just tried it by myself. You have obvioiusly downloaded the HTML page. This is what i get if using the page:
sudo wget https://github.com/wiedehopf/airspy-conf/blob/master/2.1RC/airspy_adsb-linux-arm64.tgz
--2021-08-30 21:13:19-- https://github.com/wiedehopf/airspy-conf/blob/master/2.1RC/airspy_adsb-linux-arm64.tgz
Length: unspecified [text/html]
airspy_adsb-linux-arm64.tgz.1 [ <=> ] 126.53K 238KB/s in 0.5s
2021-08-30 21:13:20 (238 KB/s) - âairspy_adsb-linux-arm64.tgzâ saved [129563]
exactly your result and this is for sure not extractable because itâs HTML:
Again, thatâs exactly what I did.
On this page, it looks like Jon has right clicked the link and used that in the wget command.
Thatâs wrong.
Need to click the link and then use the download button for the actual URL to grab.
So on a 32 bit Pi, the correct command is
wget -O airspy.tgz https://github.com/wiedehopf/airspy-conf/raw/master/2.1RC/airspy_adsb-linux-arm.tgz
NOT
wget -O airspy.tgz https://github.com/wiedehopf/airspy-conf/blob/master/2.1RC/airspy_adsb-linux-arm.tgz
Wonder how many did that too
I did the same thing yesterday⌠downloading and trying to unzip the HTML instead of raw .tgz fileâŚ
More than will admit it
I didnât think increasing gain setting would be a good idea considering the 2.1 RC change was just an RSSI measurement/reporting change if I read correctly. That said, your graphs donât show any bad side effects from your 9db increased gain.
Thatâs what i thought already by checking my signal charts. I think itâS simply not comparable with the 2.0 or previous charts. Letâsee see what the two developer guys will say
I am reverting back to my original 19 as 20 does not show any improvement in the other graphs
I did also the same. Copied the link from that page and did download it by wget
But anyway good work from the team. Also have the same effect with GND aircraft at vrs like twenteradar.
Hand up, who else?
me:
this is so confusing. where would one go to find a âprimerâ regarding this. there always seem to be some critical steps missing for those of us with limited linux knowledge. i entered the correct command, only because foxhunter showed it to me, but had no idea where it came from. when i click on the link referenced and then use the download button i get a zipped fileâŚwhat do i do with it? (again sorry for being slow)
Same advice: if your software canât deal with a few mistaken messages, you need to reduce the -e value to 5 and not use -C.
That should cut down misdecodes.
Thatâs why i provide a script for the regular versions that arenât just for testing.
You could google: how to extract tgz linux and youâd likely find an answer.
Anyhow iâll leave a âmore usefulâ answer to others.
There isnât one. This is the process I used.
First I made a temporary directory to store the downloaded files.
cd
mkdir airspy
Now change into that directory and download the new file - This is the link for the current RC for 32 bit RPi
cd airspy
That will give you a file called airspy.tgz
Exctact the file from the archive
tar xzf airspy.tgz
Now stop the service and copy the file.
sudo systemctl stop airspy_adsb
sudo cp airspy_adsb /usr/local/bin/
Now is the time to edit the config file if you want to make any changes.
sudo nano /etc/default/airspy_adsb
Save the file and restart the service
sudo systemctl start airspy_adsb
Then you can check the status - This doesnât auto update, youâll need to repeat it every ten seconds or so.
journalctl -eu airspy_adsb --no-pager
The issue itself has nothing to do with Linux. The download from Github is not always clear and easy.
If you download the HTML instead of the compressed file, the following error occurs.
The only trick in Linux is that it does not give you a warning about the HTML download. It simply does what you request.
As keithma stated the download button is the key to success:
Have you tried this?
sudo journalctl -eu airspy_adsb -f
I hadnât. But now I have, thank you
(/edit - To those who donât know, ctrl-c will get you out of this view)
Me too, but I tweaked and now the performance is a lot better. Of course, it doesnât help that I had a six hour internet outage today!
There is nothing wrong not being able to test every single test release. Especially when they are keeping rolling at a pretty high pace. Iâm pretty sure you wonât have to wait long before a regular version is available (and 2.0 is already a great version).
