I don’t understand the output of vcgencmd get_throttled but found this bash script. Still not sure I understand but I thought it might help someone …
Sometimes i lose samples too, i think due to memory bandwidth or writes/reads to/from the sd-card.
That normally happens when i do random stuff or compile something:
-- Reboot --
May 28 15:40:03 pi systemd[1]: Started Airspy ADS-B receiver.
May 28 15:40:03 pi airspy_adsb[315]: Listening for beast clients on port 29999
May 28 15:40:03 pi airspy_adsb[315]: Acquired Airspy device with serial 26A464DC287C2593
May 28 15:40:03 pi airspy_adsb[315]: Decoding started at 20 MSPS
May 28 15:40:04 pi airspy_adsb[315]: /!\ Lost 786432 samples /!\
May 28 15:40:04 pi airspy_adsb[315]: /!\ Lost 262144 samples /!\
May 28 15:40:04 pi airspy_adsb[315]: /!\ Lost 131072 samples /!\
May 28 15:40:07 pi airspy_adsb[315]: Push client connected to localhost:30004 (beast)
May 30 22:03:15 pi airspy_adsb[315]: Push client disconnected from localhost:30004 (beast)
May 30 22:03:28 pi airspy_adsb[315]: Push client connected to localhost:30004 (beast)
Jun 02 06:47:05 pi airspy_adsb[315]: /!\ Lost 262144 samples /!\
Jun 02 06:47:05 pi airspy_adsb[315]: /!\ Lost 131072 samples /!\
Jun 07 18:16:59 pi airspy_adsb[315]: /!\ Lost 131072 samples /!\
But usually no lost samples except after reboot.
I do run the RPi at fixed clock though, so it doesn’t change up and down, that helps a bit.
Apologies if this is going off on a tangent, but I have had to stop using an Anker multi port USB charger for my RPi 3 with Airpy mini - I didn’t check the voltage but assumed that the “intelligence” of the charger was limiting its output.
I have recently since switched to an Odroid XU4 due to RPi overheating, the install scripts were really helpful.
Hi all
I’m ready to up my game
i have a spare rpi3b+ BN psu 5v 3amp
biastee powered by pi usb to rtl 3filter/amp to FA antenna
going to try m20 today would i choose a much lower gain than 18 say 10 with m20 or lower see how things go
I am about to try and restore a working Airspy R2 and odroid xu4 setup. The card which was in the odroid failed. I did have this working, using ADS B project scripts, graphs etc. Now I have been trying to follow the million posts on this, including reviewing my posts when first set up. To start with, I have to have a working piaware 1090 set up working, before I attempt to include the airspy R2 into the mix. I shall do that by using a flightaware dongle onto the Odroid, keeping it simple. I will then need some help to incorporate the airspy. I shall reply to this post when stage one complete.
