I’m not sure how many people use dump1090/view1090’s interactive mode but I use it a lot when tuning and testing. To help with that, I’ve made a few enhancements and I wanted to gauge interest before submitting a pull request…
Tot: 18 Vis: 18 RSSI: Max -4.6+ Mean -19.1 Min -28.0- MaxD: 222.3nm+ Hex Mode Sqwk Flight Alt Spd Hdg Dist(nm) Bearing RSSI Msgs Ti ─────────────────────────────────────────────────────────────────────────────── AA1BA3 S2 2647 SKW2979 37000 443 179 222.3+ 65 -28.0- 228 0 A50323 S2ac 5117 AIP1814 5200 164 001 26.3 73 -24.8 376 1 AAAB73 S2a 5161 LYM1430 8575 159 337 26.7 60 -17.1 2155 0 A50F46 S2a 5155 LYM3418 8900 228 241 17.5 67 -4.6+ 2873 0 AA63E3 S2a 5151 LYM1180 11025 176 260 15.5 65 -6.3 3395 0
- There’s a summary line at the top with aircraft counts, max, mean and min RSSI and max distance.
- A new option
--interactive-show-distanceshows aircraft distance and bearing instead of lat/lon. You can change distance units with--interactive-distance-units. Of course, you have to specify a reference--lat --lonfor this to work. - The aircraft with the greatest distance is marked with a
+and the aircraft with the highest and lowest RSSI are marked with a+and-respectively. - You can limit the aircraft shown with the
--interactive-callsign-filteroption which takes a callsign prefix (actually a regular expression) and shows only those aircraft with callsigns that match. In dump1090’s case, this only limits what’s shown in the interactive display and not what’s written to files or the network.
Thoughts? Interest? Anything else that could be helpful while I’m there?
