Yes… but no.
Consider the IFR arrivals into KSAN, and more importantly, the KSAN Class B airspace and the STARs used. I’m going to leave KMYF, KSDM, and KSEE out of the picture for now. But For now, have a look at these:
flightaware.com/resources/airpor … BARET+FOUR
flightaware.com/resources/airpor … %28RNAV%29
The BARET4 and LYNDI3 arrivals handle everything coming from the east and northeast. This puts the arrival stream for those out to the Julian/El Centro/Imperial area coming in bound from the east. Now, have a look These:
flightaware.com/resources/airpor … /HUBRD+ONE
flightaware.com/resources/airpor … /SHAMU+ONE
The HUBRD1, SHAMU1, and BAYVU3 arrivals handle everything coming from the Northwest. The only differences between these are that the BAYVU3 arrival is an RNAV arrival, and the SHAMU1 arrival is used in East Operations only (read: Runway 9 is in use). These under normal operations, the HUBRD1 and BAYVU3 will bring you into the area by Mission Bay, turn you eastbound for the downwind, and join final with the rest of the arrivals (LYNDI3, BARET4). This is all pretty much down north side of the field.
Now the departures:
flightaware.com/resources/airpor … PEBLE+FOUR
flightaware.com/resources/airpor … NSAY+THREE
The LNSAY3 and PEBLE4 are used for departures to the northwest as well as oceanic departures. They’ll fly straight out, then make the turn northwest. Only difference between these is that the PEBLE4 is only used for departures off of runway 27, while the LNSAY3 can be used for both 9 and 27.
flightaware.com/resources/airpor … BORDER+SIX
The BRDR6 and POGGI2 departures are used for departures east/northeast. This makes a right turnout towards Mexico while staying inside CONUS airspace. Again, only difference is that the POGGI2 is RNAV and used only for Runway 27 departures. BRDR6 can be used for both.
Now… bring the HAL7 diversion. The way it came into KSAN’s airspace and traffic streams, it descended right into the departure corridors for the BRDR6 and POGGI2 SIDs. Why Approach decided to do that outside of an emergency or fuel, I do not know. That’s why I said it was unusual, as I would think that they’d want it coming in with the arrival stream, which would have been north of the field.
A good thing that would help you out further is that KSAN is covered by LiveATC.net, so you could listen to the tower feed for that area. they also keep a 30 day archive of the streams, so if we have the time of the incident, you could browse through the archive and hear the arrival as it happens.
Good thing to also note, is that at this current time (10:20am PDT/1720Z), KSAN is in East Operations (runway 9 in use). It is a rarity that they go to that, so if you want to see how that runs, have a listen in, and also follow the airport tracker/info here, and you’ll get a really good idea how things flow there.
Additionally, while it should NOT be used for real world navigation (I can’t stress that enough), the ZLA ARTCC on VATSIM has a really good diagram on how traffic flows into KSAN. We have real world controllers that work at ZLA and SCT that provided us that info, so it is accurate. But this should definitely help you as well.
laartcc.org/page/vectoring
BL.
