I implemented this and it seems to be working. You provide a list of flight/tail numbers (the “flight” column on the dump1090 web page), along with your email address. Whenever one of these flights/tail is picked up by your receiver, you’ll get an email. I’m using it to be notified when the Lancaster bomber is nearby to give me time to get my camera and go outside. If I wait until I hear it overhead, it’s gone by the time I get my act together!
There are two versions. One uses MySQL and the other doesn’t. I installed the “without” version. I added a CRON job to start it at boot, and a logrotate.d entry to keep the log file under control. …will see how it goes.
You need to be able to use a text editor and the command line interface in order to install this. The code is found here:
http://hfaero.com/?page_id=3273
