Hi,
Bullseyes 7.2, aircrafts are reported, Piaware and dump1090-fa status OK but, everything is RED and
“Feeder has not recently checked in with FlightAware”
Any clue ?
Hi,
Any clue ?
Can you examine your piaware logs via command line?
tail -f /var/log/piaware.log
Hi, eric1tran
Looks like there was an issue associating your account with that receiver on the backend. I’ve fixed it and should be good now.
Hi, eric1tran
The problem remains. How about if I got a new Id ?
HI, I have the same issue with the feeder no checking into FA.
Stephen Prior (user name smprior)
Can you fix this ? No reporting from my statiion for about 3 weeks. All red boxes on my stats page.
Check that your feeder is connected to the network. Can you ping it from another computer? Can you see the map and aircraft being shown? Can you ssh onto it? Ssh’d into the feeder, can you ping an IP on the Internet? You’re testing to make sure it’s up and running and can reach everything.
