Error Getting Data - When Data was showing up the few days before
Is there something wrong with my access or the server? I am no longer getting data back. This was working a few days ago, now I test again and it will not return data. Its going straight to the else (Error retrieving data from the server).
Enter flight number:swa 1511
There was an error retrieving the data from the server.
Process finished with exit code 0
import requests
import json
from settings import flight_table
username = “”
apiKey = “”
fxmlUrl = ‘https://flightxml.flightaware.com/json/FlightXML3/
flight_number = input(‘Enter flight number:’)
payload = {‘ident’: flight_number}
response = requests.get(fxmlUrl + “FlightInfoStatus”, params=payload, auth=(username, apiKey))
if response.status_code == 200:
print(“Aircraft enroute to Need to add this parameter***:”)
decodedResponse = response.json()
print(json.dumps(decodedResponse))
for flight in decodedResponse[‘FlightInfoStatusResult’][‘flights’]:
flight_table.put_item(
Item={
‘fat_flight_id’: flight[‘faFlightID’],
‘airline’: flight[‘airline’],
‘flightnumber’: flight[‘flightnumber’],
‘tailnumber’: flight[‘tailnumber’],
‘type’: flight[‘type’],
‘blocked’: 1 if flight[‘blocked’] else 0,
‘diverted’: 1 if flight[‘diverted’] else 0,
‘cancelled’: 1 if flight[‘cancelled’] else 0,
else:
print (“There was an error retrieving the data from the server.”)
Were you able to resolve the issue? I’ve run your code sample and not been able to reproduce the issue. Can you print out the response body on the error, it should have some sort of error message in there.
