1.Does wiedehopf autogain work while dump1090-fa is running or just at 0245am in the morning ??
2.Can it run along side the adaptive gain in dump1090-fa or without ??
3.Or can adaptive gain cope with auto adjusting the gain on its own ??
4. Is wiedehopf autogain more suited to readsb were it does not have adaptive gain ??
Value feedback on this
Hope this makes sense ?
setup Flightaware Pro Stick Plus v1.0
Raspberry pi 4b + RPI Buster OS
readsb doesn’t have adaptive gain, not a feature i deem necessary.
adaptive-gain will be off if you install autogain
dump1090-fa having adaptive gain … i didn’t make it work again after the config change.
still works on piaware images
Change the decoder, see how you like readsb … you can always change back to dump1090-fa easy enough.
After changing decoder, you’ll need to reinstall graphs1090 if you have that.
Few days ago on one of my Pi, I started using readsb instead of dump1090-fa (reimaged microSD card).
I have noted that the CPU and Memory usages both have gone down somewhat.
That is interesting all of you mention this .
I have enclosed screenshots of same .
The Raspberry pi4B and small screen is my testing unit ( no room to install the fan) which had also READSB installed and other software.
As you see the temp is extremely high .
About 20 minutes i installed READSB and all of the software relevant to Wiedehopf also the offline maps for Tar1090.
There is an old rtlsdr connected without an antenna but looking at the graphs1090 core temp with fan is running at Max 43c.
Wiedehopf software installation using auto scripts went well without any errors.
Away to connect the Flightaware pro plus v1.0 to the other setup with the 10inch screen and monitor the gain etc till tomorrow .
Will update next few days.
I don’t suppose you have the graphs for message rate?
That seems a lot of CPU usage for dump1090-fa, not sure it’s the norm.
Oh well … not important. Glad readsb is using CPU conservatively.
Yesterday I wrote 64-bit RaspberryPi OS on a spare microSD card, and booted RPi Model 4 with it. Next installed following (in the sequence shown below):
Readsb
Graphs1090
Flightaware feeder (piaware)
Flightradar24 feeder
Planefinder feeder
Radarbox24 feeder
Adsbexchange feeder
Let it run for 24 hrs. Today evening when I checked the graphs, I found “Messages > -3dBFS = 29.4%” and ADSB CPU usage 12%
I checked the gain setting of readsb, found it was at default -10. Changed it to 32.8.
Checked after about 1.5 hrs, found
(1) The bad red Messages > -3 dBFS have become very low
(2) The ADSB CPU usage has dropped from 12% to 6%
Probably the single biggest thing that affects CPU use is the input gain and local noise environment (i.e. how much noise gets thrown at the preamble detector) as abcd’s later graphs show. For an apples-to-apples comparison you’d need to ensure the same gain settings.
I have now slipped out the microSD card with readsb, and have slipped in another microSD card with Piaware microSD card image. Now the decoder is dump1090-fa instead of readsb.
I have set “adaptive gain = no” and manually adjusted gain to 60 (which is same as readsb’s -10). I will leave it running for a day, and tomorrow evening change gain to 32.8, as I have done with readsb, and will let it run for new gain settings for say 2 hrs and check again.
There is a problem with graphs with dump1090-fa. If adaptive gain is made “no”, the gain graph becomes blank, I dont know why. Anyway I have embedded the gain button in graphs to see the “Current Gain” along with the graphs.
Â
Â
Traffic is very low here from 2330 hrs to 0630 hrs
Yeah, this is just an unfortunate implementation accident where I put the current gain within the adaptive gain stats. no adaptive gain → no current gain. I’ve been meaning to fix that.
As the 64-bit readsb was installed on 64-bit OS, while 32-bit dump1090-fa on 32-bit OS, their performance comparison cannot be considered exact.
I will now prepare 3rd microSD card with 32-bit Raspi OS Lite, and install 32-bit readsb on it and run it to see how much is it’s ADS-B CPU Usage, first with gain -10 and after a while reducing gain to 32.8.
Following are results with Piaware SD Card image (32-bit OS + dump1090-fa)
Up to 1415 EDT:
Gain = 60
ADS-B CPU Utilization = 25%
From 14:15 EDT to !6:15 EDT
Gain = 32.8
ADS-B CPU Utilization = 20%
