Relative newbie here looking for advice. I am slowly trying to improve performance of my system and recently have been running the autogain adjust program from wiedehopf (thanks!). The program seem to be running well as my messages > -3dBFS is running at 1.9% according to graphs1090 (thanks again!). I tried to view the log of adjustments but am getting no information. Please see output below. I am running a RPI4 with FA 4.0 sd image and FA pro-stick.
pi@piaware:~ $ sudo journalctl -eu autogain1090
– Logs begin at Sat 2020-11-07 21:17:01 UTC, end at Mon 2020-11-30 20:31:24 UTC
– No entries –
…skipping…
– No entries –
There is no – Logs begin at Sat 2020-11-07 21:17:01 UTC, end at Mon 2020-11-30 There is no – No entries – option (press RETURN)
sudo systemctl list-timers --all
Check if it’s scheduled to run.
sudo systemctl restart autogain1090.service
execute it manually once like the above and check if it puts something in the log.
Thanks wiedehopf. Please see below. Looks like the timer is running but there is no service?. I noticed that there is a service running called dump1090-fa-autogain. Using the different service name got it working and the log working too!. Thanks!
pi@piaware:~ $ sudo systemctl list-timers --all
NEXT LEFT LAST PASSED
Tue 2020-12-01 00:00:00 UTC 2h 19min left Mon 2020-11-30 00:00:02 UTC 21h ago
Tue 2020-12-01 02:32:32 UTC 4h 51min left Mon 2020-11-30 02:47:02 UTC 18h ago
Tue 2020-12-01 06:35:35 UTC 8h left Mon 2020-11-30 06:19:58 UTC 15h ago
Tue 2020-12-01 16:22:52 UTC 18h left Mon 2020-11-30 19:05:36 UTC 2h 34min
Tue 2020-12-01 21:37:08 UTC 23h left Mon 2020-11-30 21:37:08 UTC 3min 27s
6 timers listed.
lines 1-9/9 (END)
NEXT LEFT LAST PASSED UNIT ACTIVATE
Tue 2020-12-01 00:00:00 UTC 2h 19min left Mon 2020-11-30 00:00:02 UTC 21h ago logrotate.timer logrotat
Tue 2020-12-01 00:00:00 UTC 2h 19min left Mon 2020-11-30 00:00:02 UTC 21h ago man-db.timer man-db.s
Tue 2020-12-01 02:32:32 UTC 4h 51min left Mon 2020-11-30 02:47:02 UTC 18h ago dump1090-fa-autogain.timer dump1090
Tue 2020-12-01 06:35:35 UTC 8h left Mon 2020-11-30 06:19:58 UTC 15h ago apt-daily-upgrade.timer apt-dail
Tue 2020-12-01 16:22:52 UTC 18h left Mon 2020-11-30 19:05:36 UTC 2h 34min ago apt-daily.timer apt-dail
Tue 2020-12-01 21:37:08 UTC 23h left Mon 2020-11-30 21:37:08 UTC 3min 27s ago systemd-tmpfiles-clean.timer systemd-
6 timers listed.
lines 1-9/9 (END)
NEXT LEFT LAST PASSED UNIT ACTIVATES
Tue 2020-12-01 00:00:00 UTC 2h 19min left Mon 2020-11-30 00:00:02 UTC 21h ago logrotate.timer logrotate.service
Tue 2020-12-01 00:00:00 UTC 2h 19min left Mon 2020-11-30 00:00:02 UTC 21h ago man-db.timer man-db.service
Tue 2020-12-01 02:32:32 UTC 4h 51min left Mon 2020-11-30 02:47:02 UTC 18h ago dump1090-fa-autogain.timer dump1090-fa-autogain.service
Tue 2020-12-01 06:35:35 UTC 8h left Mon 2020-11-30 06:19:58 UTC 15h ago apt-daily-upgrade.timer apt-daily-upgrade.service
Tue 2020-12-01 16:22:52 UTC 18h left Mon 2020-11-30 19:05:36 UTC 2h 34min ago apt-daily.timer apt-daily.service
Tue 2020-12-01 21:37:08 UTC 23h left Mon 2020-11-30 21:37:08 UTC 3min 27s ago systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
6 timers listed.
pi@piaware:~ $ sudo systemctl restart autogain1090.service
Failed to restart autogain1090.service: Unit autogain1090.service not found.
sudo systemctl restart dump1090-fa-autogain.service
pi@piaware:~ $ sudo journalctl -eu dump1090-fa-autogain
Nov 24 02:59:04 piaware dump1090-fa-autogain[21553]: No gain change needed, percentage of messages >-3dB is in nominal range. (2.703%)
Nov 24 02:59:04 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
Nov 25 02:44:57 piaware systemd[1]: Started autogain for dump1090-fa.
Nov 25 02:44:57 piaware dump1090-fa-autogain[8838]: No gain change needed, percentage of messages >-3dB is in nominal range. (2.042%)
Nov 25 02:44:57 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
Nov 26 02:41:36 piaware systemd[1]: Started autogain for dump1090-fa.
Nov 26 02:41:36 piaware dump1090-fa-autogain[30988]: No gain change needed, percentage of messages >-3dB is in nominal range. (1.748%)
Nov 26 02:41:36 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
Nov 27 02:59:29 piaware systemd[1]: Started autogain for dump1090-fa.
Nov 27 02:59:29 piaware dump1090-fa-autogain[24396]: No gain change needed, percentage of messages >-3dB is in nominal range. (2.055%)
Nov 27 02:59:29 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
Nov 28 02:33:04 piaware systemd[1]: Started autogain for dump1090-fa.
Nov 28 02:33:04 piaware dump1090-fa-autogain[9464]: No gain change needed, percentage of messages >-3dB is in nominal range. (1.888%)
Nov 28 02:33:04 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
Nov 29 02:54:57 piaware systemd[1]: Started autogain for dump1090-fa.
Nov 29 02:54:57 piaware dump1090-fa-autogain[4153]: No gain change needed, percentage of messages >-3dB is in nominal range. (2.434%)
Nov 29 02:54:57 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
Nov 30 02:47:02 piaware systemd[1]: Started autogain for dump1090-fa.
Nov 30 02:47:02 piaware dump1090-fa-autogain[25000]: No gain change needed, percentage of messages >-3dB is in nominal range. (2.076%)
Nov 30 02:47:02 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
Nov 30 21:55:12 piaware systemd[1]: Started autogain for dump1090-fa.
Nov 30 21:55:13 piaware dump1090-fa-autogain[22593]: No gain change needed, percentage of messages >-3dB is in nominal range. (1.884%)
Nov 30 21:55:13 piaware systemd[1]: dump1090-fa-autogain.service: Succeeded.
You can run the install for the new version if you want, it will remove the old one.
Anyhow you figured it out.
I thought I had installed the new one?. Are there 2 versions? I followed the adsb-scripts link on your Wiki at Github? Can you let me know the link to the new version please?
I changed it somewhat recently. Should be on the wiki page you looked at.
Anyhow it doesn’t really matter as long as it’s working.
OK I’ll just leave it as it is… if it ain’t broke…
