I’m running dump1090 via the installed piaware service on my raspberry pi. I noticed that it’s automatically launched with the following command line arguments:
/usr/bin/dump1090 --quiet --net --gain -10
Where are these arguments set/how can I change these arguments (e.g. to include the ppm correction)?
Has anyone made any changes to the default piaware dump1090 settings that have provided positive results? What advantages does dump1090-mutability provide over the stock piaware SD image?
Back when I was playing around with settings in dump1090, the biggest improvement by far was setting gain to -10. I saw about a 50% improvement in planes, although that was before adding a high pass filter.
The gain of -10 is the default these days, so not too much to gain (NPI) by playing with the dump1090 settings, although the settings for --lat & --lon appear to be passed to FlightAware these days.
Mutability has a lot of nice features in the local display along with oversampling support. It improved my reception by about 5% (from a fairly optimized setup) with no other changes. It was a little tricky to configure at first, until I figured out the format of /etc/default/dump1090-mutability. I would definitely say the upgrade to mutability was worthwhile.
I like playing with the arguments in the fadump1090.sh file, but tend to loose track of what I did when etc.
So I hacked a quick one-liner and did a vi on the extension.js file
Started by creating a file that shows the last time the fadump1090 was modified and I then pull the PROG_ARG line from the file and write this information to the pubic_html folder in a file called args.txt.
sudo vi /etc/init.d/fadump1090.sh
insert the code below , between the line ** log_begin_msg $status** and return in the start function.
sudo vi /usr/share/dump1090/public_html/extension.js
Insert the code below above function extendedInitalize() {
xmlhttp = new XMLHttpRequest();
xmlhttp.open("GET","args.txt",true);
xmlhttp.onreadystatechange=function() {
if (xmlhttp.readyState==4) {
var info = "<HR>"+ xmlhttp.responseText;
document.getElementById('plane_extension').innerHTML=info;
xmlhttp.send(null);
sudo /etc/init.d/fadump1090.sh restart
This allows me to see the arguments in dump’s map on ip:8080
