Hello,
Today I’ve noticed that the used space in the SD Card is slowly increasing. Does your system show a similar behavior?
Currently running PiAware (SD Card) 5.0.
Hello,
I can’t say it does.
You could do a cleanup on your system with the following commands ![]()
Sudo apt-autoremove ( this will remove no longer used packages)
Sudo apt-get clean ( this will remove the downloaded packages from the local storage). If they are needed in the future they are automaticly downloaded again.
There is something really wrong on the device. That fast increase is not normal. Having the feeder only should not take more than 2-3 GB stable.
try running the command
sudo du
from the root folder, this might give you an idea which folder contain the files taking that much.
More options on that command:
Linux commands: du and the options you should be using | Enable Sysadmin (redhat.com)
After cleaning log files in /var/log it’s better, have to check this more often.
Thank you all for the information.
Yeah but it’s still not normal having such an increase after few months.
That’s mine after 2 1/2 months, using a 64 GB SD card
And beside the feeder i also have WeeWX (weather station software) with Apache and MySQL running together with an InfluxDB/Grafana instance on the same device
I’d thought logrotate should keep your files to a reasonable size. Just deleting logs has not fixed the issue which will recur; what is making the logs grow so fast. Some info/warning/error that is repeating frequently ?
Before deleting the files it would have been good looking on their list…
But now it’s too late
I’m monitoring the logs size and next time I will save then before delete.
After 9 days I haven’t seen any major increase in used space.
In the daemon.log I can see a lot of " Can’t connect to 978 source (127.0.0.1:28380). Waiting 5 second…", is there any way to stop this process?
total 234M
-rw-r--r-- 1 root root 0M Sep 14 2020 alternatives.log
-rw-r--r-- 1 root root 1M Sep 7 2020 alternatives.log.1
drwxr-xr-x 2 root root 1M Mar 31 00:00 apt
-rw-r----- 1 root adm 3M May 31 09:35 auth.log
-rw------- 1 root root 4M May 31 00:01 boot.log
-rw-r--r-- 1 root root 0M Mar 24 2020 bootstrap.log
-rw-rw---- 1 root utmp 0M May 31 00:00 btmp
-rw-rw---- 1 root utmp 0M May 28 00:00 btmp.1
-rw-r--r-- 1 root adm 81M May 31 09:35 daemon.log
-rw-r--r-- 1 root adm 1M May 31 00:02 debug
-rw-r--r-- 1 root adm 1M Nov 28 2020 debug.1
drwxrwxrwx 2 root root 1M Apr 17 2020 dirmngr
-rw-r--r-- 1 root root 0M Mar 31 00:00 dpkg.log
-rw-r--r-- 1 root root 1M Mar 26 08:11 dpkg.log.1
-rw-r--r-- 1 root root 1M Sep 16 2020 dpkg.log.1.gz-2020092100.backup
-rw-r--r-- 1 root root 1M Oct 16 2020 dpkg.log.1.gz-2020101800.backup
-rw-r--r-- 1 root root 1M Nov 2 2020 dpkg.log.1.gz-2020110600.backup
-rw-r--r-- 1 root root 1M Sep 15 2020 faillog
-rw-r--r-- 1 root root 0M Mar 24 2020 fontconfig.log
drwxr-xr-x 2 fr24 fr24 1M May 21 12:38 fr24feed
-rw-r--r-- 1 root root 0M Apr 17 2020 fr24feed_install_dump1090.log
-rw-r--r-- 1 root root 1M May 31 08:11 fr24feed_update.log
-rw-r--r-- 1 root adm 7M May 31 00:01 kern.log
-rw-r--r-- 1 root adm 1M Nov 28 2020 kern.log.1
-rw-rw-r-- 1 root utmp 1M May 31 09:20 lastlog
drwxr-x--- 2 www-data www-data 1M May 31 00:00 lighttpd
-rw-r--r-- 1 root adm 6M May 31 00:01 messages
-rw-r--r-- 1 root adm 1M Nov 29 2020 messages.1
-rw-r--r-- 1 root root 9M May 31 09:30 mlat-client.log
-rw-r--r-- 1 root root 3M May 24 00:00 mlat-client.log.1
-rw-r--r-- 1 root root 1M May 19 00:00 mlat-client.log.2
-rw-r--r-- 1 root root 4M May 17 00:00 mlat-client.log.3
-rw-r--r-- 1 root root 1M May 15 00:00 mlat-client.log.4
-rw-r--r-- 1 root root 4M May 10 00:00 mlat-client.log.5
-rw-r--r-- 1 root root 0M Oct 25 2020 nodered-install.log
-rw-r--r-- 1 root root 1M Sep 7 2020 nodered-install.log.1
drwxr-xr-x 2 ntp ntp 1M Mar 21 2019 ntpstats
drwxr-xr-x 2 root root 1M May 30 21:02 pfclient
-rw-r--r-- 1 root adm 2M May 31 09:33 piaware.log
drwx------ 2 root root 1M Mar 24 2020 private
-rw-r--r-- 1 root root 22M May 31 09:35 rbfeeder.log
-rw-r--r-- 1 root adm 83M May 31 09:35 syslog
-rw-r--r-- 1 root adm 9M Dec 1 00:00 syslog.1
-rw-r--r-- 1 root adm 0M Oct 29 2020 syslog.1.gz-2020112200.backup
-rw-r--r-- 1 root adm 1M May 31 00:00 user.log
-rw-r--r-- 1 root adm 1M Nov 28 2020 user.log.1
-rw-r--r-- 1 root root 1M May 31 00:01 vrsw-adsb.log
-rw-r--r-- 1 root root 1M May 31 09:30 vrsw-mlat.log
-rw-rw-r-- 1 root utmp 1M May 31 09:20 wtmp
if you are not using UAT 978 ( USA only) then you can use the following commands to disable the 978 reciever.
If you ever want to add a 978 reciever you can use the 2nd part of the commands below.
9.2 - If you want to run 1090 Mhz only
In this case, you will need only one dongle, but you will have to disable dump978-fa by following command
sudo piaware-config receiver-type rtlsdr
sudo piaware-config uat-receiver-type none
To re-enable dump978-fa (requires an additional dongle for dump978-fa)
sudo piaware-config uat-receiver-type sdr
You should have log messages in journalctl in memory.
Really there is no need for /var/log very much …
I’d just
sudo apt remove rsyslog
And get rid of redundant logging.
I will show your statement to the Radarbox team ![]()
On my end this is the one causing most traffic in my var/log without giving much value. Therefore i’ve moved this particular log to Ramdisk and write it once a night to disk.
Checking my CPU use wioth and without Radadrbox24.com active. It takes a lot of CPU when I open the site on my Macbook.
Radarbox24.com open
Without Radarbox
It seems Radarbox is taking a lot of CPU%
Does everyone have the same experience? Noticed it before, but after reading this thread I decided to check it again.
