Wow, that’s a lotta data.
Thanks for checking in.
J
J
I think notepad is adding a .txt file extention that I haven’t worked out a solution for yet.
just add quotation marks around the filename in Notepad and it won’t add the extension. ie. “ssh”
What did you do to block access? Did you change permissions on the file? My system shows permissions: -rw-r–r-- 1 dump1090 nogroup 21840 Oct 31 02:39 aircraft.json
No, I did it through lighttpd
sudo nano /etc/lighttpd/lighttpd.conf
And I added these lines:
# deny access to /aircraft.json in tar1090/data
$HTTP["url"] =~ "^/tar1090/data/" {
url.access-deny = ("aircraft.json")
Then restart lighttpd
The lighttpd service doesn’t start anymore with those lines added.
Missing a } at the end.
Anyway, the net usage increased after adding the lines and restarting. Average before was like 8.7kB/sec now I am getting like 14kB/sec:
My data usage, for 120-150 planes at peak time, is about 750 MB/day.
22 GB/month.
Yes, sorry. I’ve added it.
During my peak months where i had feeds also to Radarbox and Opensky there were up to 3 GB a day which end up in around 90GB per month while having >3000 Aircraft registered per day.
Especially Opensky does not compress or combine data and therefore causes a high usage. I stopped these two and the traffic is down to 30 GB per Month
In US there is barely any MLAT, majority (99% in my case) switched to ADS-B, except some military planes. Stopping MLAT reduces enormously the data usage, if somebody needs that.
My example:
SoNic,
Thanks a ton for chiming in!! After reading your last post, I disabled 1090 MLAT and believe that may have been my culprit.
J
