I’ve found some issues in the process of migrating from FlightXML2 to AeroAPI.
an example result from FlightXML2/SearchBirdseyeInFlight:
"faFlightID": "FD467-1692145623-fds-1627p",
"ident": "FD467",
"prefix": "",
"type": "BE20",
"suffix": "",
"origin": "YBRK",
"destination": "YBBN",
"timeout": "0",
"timestamp": 1692161029,
"departureTime": 1692157211,
"firstPositionTime": 1692156971,
"arrivalTime": 0,
"longitude": 152.87279,
"latitude": -27.03557,
"lowLongitude": 150.47385,
"lowLatitude": -27.03557,
"highLongitude": 152.87279,
"highLatitude": -23.37305,
"groundspeed": 222,
"altitude": 98,
"heading": 178,
"altitudeStatus": "",
"updateType": "A",
"altitudeChange": "D",
"waypoints": "-27.384 153.12"
and the equivalent result with aeroapi/flights/search:
"ident": "FD467",
"ident_icao": "FD467",
"ident_iata": null,
"fa_flight_id": "FD467-1692145623-fds-1627p",
"actual_off": "2023-08-16T03:40:11Z",
"actual_on": null,
"foresight_predictions_available": false,
"predicted_out": null,
"predicted_off": null,
"predicted_on": null,
"predicted_in": null,
"predicted_out_source": null,
"predicted_off_source": null,
"predicted_on_source": null,
"predicted_in_source": null,
"origin": {
"code": "YBRK",
"code_icao": "YBRK",
"code_iata": "ROK",
"code_lid": null,
"timezone": "Australia/Brisbane",
"name": "Rockhampton",
"city": "Rockhampton",
"airport_info_url": "/airports/YBRK"
"destination": null,
"waypoints": [],
"first_position_time": "2023-08-16T03:36:11Z",
"last_position": {
"altitude": 98,
"altitude_change": "D",
"groundspeed": 222,
"heading": 178,
"timestamp": "2023-08-16T04:43:49Z",
"update_type": "A"
"bounding_box": [
-23.37305,
150.47385,
-27.03557,
152.87279
"ident_prefix": null,
"aircraft_type": null
There are fields that are empty in AeroAPI, that I require for my specific use case. They are the “destination” and “aircraft_type” fields.
These are obviously accessible to FlightXML so its not a case of the information not existing.
Is this a known issue? And would I be able to expect this to be solved in the near future, especially considering the end of service of FlightXML?
Also am I right to assume AeroAPI::actual_off is equivalent to FlightXML::departureTime ?
After epoch conversion they seem to be the same times, but I couldn’t find a definitive answer.
Edit: phrasing
