I am running PiAware, Site 13163. For the past few days I have had to keep resting PiAware and dump1090 from the stats page on FA. I went to sleep last night and all was fine, I woke up this AM and my log looked like this:
[2015-10-28 07:09 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:09 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:09 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:09 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:09 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:12 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:12 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:12 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:12 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:12 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:21 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:21 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:21 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:21 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:21 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:22 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:22 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:22 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:22 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:22 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:25 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:25 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:25 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:25 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:25 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:25 EDT] multilateration data requested, enabling mlat client
[2015-10-28 07:25 EDT] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --results beast,connect,localhost:30104 --results ext_basestation,listen,30106 --udp-transport 70.42.6.198:6583:2959048375
[2015-10-28 07:25 EDT] mlat(22885): fa-mlat-client 0.2.4 starting up
[2015-10-28 07:25 EDT] mlat(22885): Using UDP transport to 70.42.6.198:6583
[2015-10-28 07:25 EDT] mlat(22885): Listening for Extended Basestation-format results connection on port 30106
[2015-10-28 07:25 EDT] mlat(22885): Input connected to localhost:30005
[2015-10-28 07:25 EDT] mlat(22885): Beast-format results connection with localhost:30104: connection established
[2015-10-28 07:28 EDT] 62913 msgs recv’d from dump1090 (1078 in last 5m); 45762 msgs sent to FlightAware
[2015-10-28 07:38 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:38 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:38 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:38 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:38 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:40 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:40 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:40 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:40 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:40 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:59 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 07:59 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:59 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 07:59 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 07:59 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 07:59 EDT] multilateration data requested, enabling mlat client
[2015-10-28 07:59 EDT] Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --results beast,connect,localhost:30104 --results ext_basestation,listen,30106 --udp-transport 70.42.6.198:9339:3781927975
[2015-10-28 07:59 EDT] mlat(3856): fa-mlat-client 0.2.4 starting up
[2015-10-28 07:59 EDT] mlat(3856): Using UDP transport to 70.42.6.198:9339
[2015-10-28 07:59 EDT] mlat(3856): Listening for Extended Basestation-format results connection on port 30106
[2015-10-28 07:59 EDT] mlat(3856): Input connected to localhost:30005
[2015-10-28 07:59 EDT] mlat(3856): Beast-format results connection with localhost:30104: connection established
[2015-10-28 08:04 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 08:04 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 08:04 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 08:04 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 08:04 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 08:19 EDT] autoUpdate is not set in adept config, looking further…
[2015-10-28 08:19 EDT] autoUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 08:19 EDT] manualUpdate is not set in adept config, looking further…
[2015-10-28 08:19 EDT] manualUpdate in /etc/piaware is enabled, allowing update
[2015-10-28 08:19 EDT] multilateration support enabled (use piaware-config to disable)
[2015-10-28 08:19 EDT] multilateration data requested, enabling mlat client
[2015-10-28 08:19 EDT] Starting multilateration client: /usr/lib/piaware/helpers/fa-
It seemed to be stuck in this loop. I reset Pi and dump and now all is working. Considering my recent issues, I am thinking about doing a fresh install of Pi and Noobs on a clean card. Any thoughts? Is it me or FA? I also stream to FR24 and things seem to be okay there. Thanks.
