Connection refused piaware-ipv6.flightaware.com
For the last 6 hours or more I have been getting:
May 23 09:17:22 piaware piaware[610]: piaware received a message from beast-splitter!
May 23 09:23:20 piaware piaware[610]: 209 msgs recv'd from beast-splitter; 0 msgs sent to FlightAware
May 23 09:23:20 piaware piaware[610]: Connecting to FlightAware adept server at piaware-ipv6.flightaware.com/1200
May 23 09:23:20 piaware piaware[610]: Connection to adept server at piaware-ipv6.flightaware.com/1200 failed: connection refused
May 23 09:23:20 piaware piaware[610]: reconnecting in 68 seconds...
May 23 09:23:50 piaware piaware[610]: 1144 msgs recv'd from beast-splitter (935 in last 1m); 0 msgs sent to FlightAware
May 23 09:24:28 piaware piaware[610]: Connecting to FlightAware adept server at piaware-ipv6.flightaware.com/1200
May 23 09:24:29 piaware piaware[610]: Connection to adept server at piaware-ipv6.flightaware.com/1200 failed: connection refused
May 23 09:24:29 piaware piaware[610]: reconnecting in 53 seconds...
Is this a DNS problem?
Reboot does not help.
UPDATE
>ping -6  piaware-ipv6.flightaware.com
Pinging piaware-ipv6.flightaware.com [2620:13d:c000:11::196] with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 2620:13d:c000:11::196:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
So temporary solution appears to be:
 $ piaware-config adept-serverhosts "piaware-ipv6.flightaware.com piaware.flightaware.com"
Set adept-serverhosts to piaware-ipv6.flightaware.com piaware.flightaware.com in /boot/piaware-config.txt:86
 $ sudo systemctl restart piaware
You should have posted it in this sub-forum. The experts are looking at it more often:
Latest FlightAware/ADS-B Flight Tracking topics - FlightAware Discussions
Maybe @obj is able to check it
Thanks for the advice @foxhunter - I’ve moved it accordingly.
The default config will try both v4 and v6 addresses – if you have connectivity for both, you probably want to just leave it at the default and not override adept-serverhosts at all. (At some point in the past you’ve overridden this to be v6-only)
I’m looking into what’s gone wrong on the v6 side.
Thank you @obj
I had one site configured for v4 and another for v6.
The latter failed connection around 3am on 23rd May - fortunately the alert email warned me, so streak left intact.
Should be fixed now, sorry for the hassle!
