We’re trying to implement the FlightAware codeshare to verify the different flight numbers for the same flight.
But it doesn’t return the primary operator of the flight.
We have check the documetation and found that FlightInfo are support the codeshare (we use FlightInfo to get the flight data)
src = FlightXML2 Web Services <div style="border: 1px solid black"> <h3>Want the latest version of AeroAPI? </h3> <p style="color:red; font-size:25px;">Important update: You have reached documentation for AeroAPI version 2 (FlightXML2), which will reach end-of-life October 2023. If you are currently using this version, please make plans to migrate to version 4 in the near future.</p> <p>We recently introduced AeroAPI v4, FlightAware's next-generation RESTful API for accessing comprehensive flight data. Offering a more advanced and easier to use platform! </p> <div style="text-align:center;"> <ul style="text-align:left;display:inline-block;"> <li>RESTful/JSON - following latest standards and open API 3.1 specifications </li> <li>Enhanced flight information and deeper data content </li> <li>Comprehensive interactive online developer documentation</li> <li>Foresight predictions now available </li> </ul> </div> <a href="https://www.flightaware.com/commercial/aeroapi/">Explore the latest AeroAPI</a> or <a href="https://www.flightaware.com/aeroapi/portal/documentation">See latest AeroAPI Documentation</a> <br> </div> <br> FlightXML2 Web Services
We have provide the correct inputs (ident & howMany) for FlightInfo, here is the implementation =
protected function getSoapClient()
if (empty($this->_soapClient)) {
$this->_soapClient = new \SoapClient(
$this->_apiUrl . $this->_soapPath,
array(
'trace' => true,
'exceptions' => 0,
'login' => $this->_apiUsername,
'password' => $this->_apiKey
return $this->_soapClient;
protected function _toArray($object)
return json_decode(json_encode($object), true);
public function flightInfo($ident, $howMany)
$param = array(
'ident' => $ident,
'howMany' => intval($howMany)
if ($this->_debug) {
$this->_log('FlightInfo', $param);
$result = $this->getSoapClient()->FlightInfo($param);
$this->_log('FlightInfo return:', array($result));
return $result;
//call function example
$flightInfoResult = $this->_toArray($this->flightInfo($flightCode, 15));
But it still not working on codeshare
return result when we are using S74736
[2021-03-24 03:43:56] main.DEBUG: FlightInfo return: [“[object] (SoapFault(code: 0): NO_DATA no data available at /home/cloudpanel/htdocs/melair/app/code/Omnyfy/FlightAware/Helper/Data.php:144)”]
But it works when we are using the primary operator flight code QR905
