Check-in feeders delayed
Since a few weeks I’m getting notifications that some of the setups have not reported in at Flightaware.
When checking the logs they are normally reporting but it can take up to 20-30 minutes before the notification is cleared again.
Last time this happened was in 2021 when something on the backend of the FA servers was changed. Has there been a change again causing this behavior?
The stations are reporting normally and the statistics are also fine just wondering why this message keeps popping up at irregular times on different setups.
Roger that Mr. Tom. I am experiencing the same thing here on this side of the pond. Seeing Red!
Can you guys DM me the notification and which receivers you’re seeing this on?
Check you inbox :wink: for the information from my setups. If other numbers show the same I will follow that up with the additional numbers
Eric I have sent you a direct follow up message. Thanks for the follow up.
