There is something else going on here that we haven’t figured out as of yet. The chances of the filter alone causing this issue are very slim. I’ve installed quite a few of the exact same filter and have never seen issues like this. At the same time, I refuse (as a former Comcast data/fiber field tech for around a decade) to be in the same room with twist-on coax end fittings. It’s instinct for any cable tech that’s worth anything to automatically change out every twist-on fitting we see with quality snap-and-seal fittings whenever required. If gold store-bought splitters and twist-on coax fittings didn’t exist, the cable companies wouldn’t need nearly as many techs as they currently employ. Those items are the ultimate source of all sorts of problems at literally hundreds of thousands of service calls every year.
I do understand that this is a hobby and certainly wouldn’t expect you to go out and buy a cable stripping tool, expensive fittings, and a fitting compression tool just to slap a FlighAware feeder setup together on your roof.
That said, I’m curious to know how you went about stripping the coax prior to installing those lovely twist-on fittings, and how much (or how little) of the copper center-conductor you left sticking out beyond the end of the fittings? Just because you’re using twist-on fittings, that doesn’t necessarily mean that they can’t work just fine for this project (if they’re installed correctly).
Unless you somehow got a screwy filter (not likely), something has to be physically wrong somewhere in your setup for the filter install to kill your numbers to the degree that it did. I’m going to guess that the problem is somewhere within the adapters you used when inserting the filter between the power inserter and the SDR dongle (red circles). I’m curious to know if you’d be willing to unscrew the short coax jumper you had running between the power inserter and the filter and provide us with some clear photos looking down in to the coax fittings on each end of that little cable (green arrow)? Small imperfections with adapters, fittings, etc. can lead to big problems when dealing with frequencies in the 1GHz range, which may very well be what we’re dealing with here.
As for as your setup on the roof, your antenna location is fine and there is no reason to worry about moving it away from the dish. Your spider is higher than the dish and the metal from the dish isn’t going to block any aircraft signals that low to the ground anyway.
With your current setup and plenty of open sky, you could get away with adding a longer piece of coax to the end of the antenna and moving the amp, Pi, etc. inside without noticing much of a difference in aircraft count. I know you said that it’s not going to rain for a while, but if it should so much a sprinkle once with all of that stuff out there, it will all be ruined.
Also, getting the Pi and dongle (in particular) inside will at least somewhat help to shield the dongle from the insane amount of RF that it is absorbing by being out in the open on your roof.
As a side note, ‘rebooting’ your Pi by simply unplugging it is really not a good idea and will, after enough of those, almost certainly lead to corrupt data on your SD card (which means you’ll get to start all over again). In testing, I’ve seen as few as 4-5 power-loss reboots destroy the OS install on a MicroSD card.
To properly shutdown a Pi, you need to first log-in to it and issue the proper shutdown / halt command - but we’ll get to that later.
In the case of modifying your RF chain, there is no need to reboot the Pi as it has no idea what you’re doing out there anyway. Once you’ve made whatever changes you’re making, it’ll start receiving the better (or worse) data from aircraft and take care of things on it’s own.
Based on the numbers you’re already putting up on your stats page and your rather prime location near the Bay Area, there is no reason why you couldn’t be putting up much higher numbers with some setup tweaking. You’re already doing better than most folks that are much closer to SFO/OAK/SJO, and with some help from the good people in these forums, I’m sure we can get you running even better.
Matt,
My experience with the Perfect Vision amp has been the complete opposite to yours and I am wondering why. What did we do differently to have such opposing views?
If you look at my stats page you’ll find two feeding sites, 6458 & 8130. And here is their configuration, at present.
site 6458, CoCo antenna—5m RG6—Nevis LNA/filter—Dongle—RPi2
site 8130, Spider—5m RG6—Perfect Vision Amp—Power/Inserter—Splitter—Dongle—BPi
The two sites report almost the same stats, except the spider’s RF reports slightly less due to being mounted 1.5m lower. And I can swap the RF chains from box-to-box and the same pattern follows within the stats.
The biggest light-bulb moment for me with the Perfect Vision amp was when I was playing with the splitter. The splitter has 3db insertion loss, so I figured that I would see a reduction in range and/or aircraft spotted, but the opposite was the case. So, the only thing I can figure is that perhaps the PV amp was over-driving the dongle and the added splitter loss helped the dongle in AGC mode to handle the signal better.
To eliminate other factors that the splitter might be causing, I plan on trying a simple 3db pad to see the effect.
…Tom
After I get back to work today I am going to check the continuity of the filter with the connectors and see if that is the problem.
Every time I change the antenna, coke can to spider or unhook the cables to install the amp it can take several hours for the system to start reading?? Kinda impossible to go in and hook it to a monitor and issue the command to reboot. Can this be done on the stats page?
I am certainly interested in learning how to get the most of this system so any and all advice is valuable.
Will post the continuity of the filter arrangement after I get back from flying this morning. By the way, I had removed that short piece of coaxial cable originally and it still did not report anything so I put it back in as an attempt to get the system to read again. I have it installed right not so I have to feel it works. Why screw on ends… Simple, easy, cheap and I had never put an end on a coaxial cable before so I had to try something to start with and them improve from there.
Didn’t even get to work and I saw that there’s no wire inside the adapters to make the connection between the SMA to the F type adapter on one end… So essentially there was no antenna feed going into the Dongle.
Wonder if I can just pull one of these wires out of another connector and insert into this one… hmmmm??
Also wonder which is wrong, the filter or the adapter, common sense says the adapter…
Looks like your adapter is reverse sex. For a quick test you may be able to put some wire in to allow
it to make connection. But for a solid fix I would get the right adapter and move it out of the weather.
Thanks, finding this adapter is not that easy. Got one, make that two on ebay a few minutes ago from good old CHINA.
Have to wait a week but have to wait a week for domestic shipping as well so that’s a wash.
It’s been less than 24 hrs since I removed the filter and I have already seen 1,070 planes so the system is working well and now that I have found the problem with the filter setup I have hope again for more.
While you wait, cut a couple short pieces of coax centre conductor and try and make the adapters work. I wouldn’t be able to wait for the new adapters to arrive, but that’s just me…
…Tom
Funny you said that… I immediately went and cut a 2" piece off the coaxial bundle… Stripped it and though this is going to be easy… To large of a diameter!!! Will not fit in either end… Then I ordered a new end.
Measured the coaxial rod at 0.04" or 1mm and the SMA is 0.036" so I might take a razor blade and scrap the wire down a bit and try it.
1 mm dia is 18 awg. If you have any single components like resistors, capacitors or diodes you may find one or more with the right gauge wire leads attached.
P.S. do you have a pneumatic brad nailer? Some use 18 gauge brad nails.
…Tom
I really wouldn’t recommend that as it’s not worth taking a chance at damaging the pins inside that $40 filter - and you likely don’t have any wire that is as thin as what would be sticking out of a male SMA plug. The filter is just an added bonus for your setup, which is already working well without it. Just wait for your adapter to arrive.
The filters only come one way, and actually needing an RP-SMA adapter for something is pretty rare.
Guessing you just hooked the filter and the adapter together and didn’t look to make sure they would actually mate together correctly?
Actually, they stock them in just about every Amazon distribution center in the country and you can get one within 2-3 days (4-5 days with free shipping). I just ordered a few more F-Female to SMA-Male adapters on Monday night and they arrived today.
You have two realistic options that are actually stocked and shipped by Amazon, which means they’ll arrive quickly:
This is the adapter you’d need to go directly from the output of the filter to the MCX input on your USB dongle, which would eliminate chaining multiple adapters together (which it appears you were doing in your original photos):
I have never used PerfectVision or MiniCircuit’s Amplifier. The only amplifier I have used is RCA D903, which I purchased from a local Hobby & Eectronics Store for $4.
I am using it since 2 years, and am very satisfied with it.
Here is the picture of my first setup which I made 2 years ago:
A halfwave dipole → Amplifier-> 50 ft/15m RG6 coax->DVB-T dongle->Desktop (Windows).
I suspect that all these amplifiers are pretty similar - the main difference is what’s printed on the casing.
What ha made most difference on my Pi B was doing sudo raspi-config and overclocking it to ‘medium’ - it’s lifted my message count on dump1090 by almost 20%.
Well curiosity got the best of me and I took the coaxial core and put it in a lathe and took two files and spun the wire between them until I had the diameter down to 0/035" and then the wire fit!!!
Cut the wire at a good length and put the filter and adapter arrangement back together.
Went and installed the filter back in the system and it appears to be working now.
Not a lot of difference. Note: I used the command line to reboot the Pi as I didn’t want to wait hours for the filter installation to take place. Up and running in a matter of 10 minutes from start to finish.
