Okay not sure why, but yesterday I finally combined my UAT receiver that was running on a seperate Pi onto the 1090 pi. Everything appears to be working fine, MLAT is green and shows it’s in sync yet I’ve lost sync with stations near me. Anyone have a clue what could be the problem here? I’m using an AirSpy for 1090 and I’m not showing any lost samples.
@jonhawkes2030 is absolutely correct - MLAT flat out won’t work if another USB device is plugged in on a Raspberry (any iteration) alongside the Airspy. You may not be showing dropped packets, but there is not enough bandwidth on the shared USB hub on a Raspberry. It will work on a RockPi 4b, but have not tested Odroid or any others - most SBC’s (currently) don’t have seperate USB hubs built-in to handle the excessive bandwidth if another device is plugged in.
Well … if your timing is really bad, it can’t even get a sync to nearby receivers to generate a sync error.
This is hard to differentiate from working MLAT and no stations / aircraft to sync to / with.
Anyhow if you change to 12 MHz … and it improves then you know what the issue is.
