Thanks, good to know.
The piaware package contains following helpers, irrespective of what you use as decoder
- faup1090
- faup978
- fa-mlat-clent
The failure occured during making of faup978 helper. Please see below your error message.
Run the script for piaware again. Most likely it will succeed.
Maybe you are running out of memory?
I built from source all the FA packages on my system and was able to upgrade them without an issue, but yeah, when it hit the bit about faup978 the package build process slowed down markedly and took a few minutes to move forward.
Well gave it another go, rebooted prior to the installation when logged in prior to the reboot I saw that the MEM and SWAP file were completly in use. So there might have been an memory issue but since the others did run fine that didnât come to mind this morning.
Ran the command again after the reboot and this time it completed without errors.
So my guess the rootcause of the error was operator induced since I didnât do the reboot after the update of dump1090-fa as advised by the script
I got dump1090-fa
, piaware
and piaware-web
version 10 working but
dump978-fa
was a no-go. Got the following error:
g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
make[2]: *** [<builtin>: dump978_main.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[2]: Leaving directory '/home/pi/dump978/package-bookworm'
dh_auto_build: error: make -j4 "INSTALL=install --strip-program=true" VERSION=10.0 dump978-fa skyaware978 returned exit code 2
make[1]: *** [debian/rules:13: override_dh_auto_build] Error 2
make[1]: Leaving directory '/home/pi/dump978/package-bookworm'
make: *** [debian/rules:22: build] Error 2
dpkg-buildpackage: error: debian/rules build subprocess returned exit status 2
[ERROR] Error in line 113 when executing: sudo dpkg-buildpackage -b --no-sign
The last line before the error was:
g++ -g -O2 -ffile-prefix-map=/home/pi/dump978/package-bookworm=. -fstack-protector-strong -fstack-clash-protection -Wformat -Werror=format-security -mbranch-protection=standard -std=c++11 -Wall -Wno-psabi -Werror -O2 -g -Ilibs -Wdate-time -D_FORTIFY_SOURCE=2 -DVERSION=\"10.0\" -c -o soapy_source.o soapy_source.cc
I have installed it on a PiZero2W and a Pi3B with great sucess.
Also running on Pi4 and Pi5 all running Bookworm.
Thanks for the suggestion.
S
This may be due to memory (ram+swap) being full.
Please reboot Pi and try again.
Please see these posts:
Yeah, it could be a memory problem. This is on a 2 GB RPi4. Iâve tried to compile it several times and sometimes it just freezes on that line I posted above (i.e doesnât even show an error message). Iâll probably have to wait until a pre-complied version is available.
A default setting in dpkg-buildpackage is to detect the number of processors on your system and match that to how many jobs can run in parallel. Iâm guessing the number of jobs is too many for the limited memory you have (see the âwaiting for unfinished jobsâ error msg in the log you posted).
One idea is to add -j1 to the dpkg-buildpackage command which will force jobs to run serially instead of in parallel. It will take longer to compile, but it may get you around the memory issue.
@jimMerk2
@dvsvejk
@tomvdhorst
Building dump978-fa is memory-intensive, and fails if sufficient memory is not available
Anyone faced with memory problem during building of dump978-fa can increase memory by create a temporary swap file of say 2GB, so that total memory becomes 2GB ram + 0.5 GB swap +2 GB swa-file = 4.5 GB.
After the dump978-fa package is built successfully, the swap-file created by user can be deleted to free up disk space.
I have described in detail the method to create a swap-file in following post:
NOTE:
(1) - On RPi, you cannot switch user to root. Instead use sudo
with all commands mentioned in above noted post.
(2) You cannot delete swap file created by you unless you make swap off.
To delete the swap file you created, use following commands
sudo swapoff /my-swap
sudo rm /my-swap
Open file fstab
for editing
sudo nano /etc/fstab
In above file, delete following line which you have added while creating your swap file
/my-swap none swap sw 0 0
For you (and any others interested), hereâs a couple of âusefulâ nuggets.
Go to the bash shell (either locally, or using ssh) and type the following line:
alias piaware=âjournalctl -f -u piawareâ - Iâve used âpiawareâ, but you can select any term you like.
then press Enter. clear the screen (clear), then invoke the alias typed above and youâll get an update about the messages sent, receiver status, displayed, which is updated evert 5 minutes.
Use Ctrl-C to exit back to a bash prompt.
In Raspberry Pi OS, by default the password for root is unset. Swithing to user ârootâ is not possible unless password for root is first set. In RPi OS this is not considered good practice, and a better option is to use sudo
with a non-root user such as âpiâ
The idea is that if you are in front of a login prompt of someone else machine, you have to guess two things to get in: a user name and a password
If root logins are allowed you know every machine has a ârootâ user so that is one less thing to guess. Much easier, especially important if you have ssh enabled on the internet.
Thanks, I added a 2 GB swap file and was able to successfully build dump978-fa.
I was going to ask why I should remove the swap file after using it. However, I found out that if I just left it in, dump1090-fa
would not produce any messages. Donât know why that was, but then removed the swap file and dump1090-fa
started working again.
How did you find that NetworkManager disabled wifi? Did you just run ânmcli radioâ?
How did you turn the wireless LAN on?
Bookworm disables some devices by default. Weâve changed stuff to have wifi enabled by default.
So Iâm curious why it was disabled for you.
Playing with v 10 and cant log in
don config ssh.txt
have you got user pass please
Remember fat fingers means wrong letters
config.txt ssf lolol
sorted that still no luck
Finally, I ended up with a beautiful SD PIAWARE CARD 10.0
THANKs abcd567 for spending time to do this for us.
login as: Pi
Pi@192.168.x.xâs password:
Linux raspberrypi 6.6.74+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.74-1+rpt1 (2025- 01-27) aarch64
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Mar 3 18:44:03 2025 from 192.168.1.5
Pi@raspberrypi:~ $ cat /proc/cpuinfo | grep Model
Model : Raspberry Pi 3 Model B Plus Rev 1.3
Pi@raspberrypi:~ $ uname -a
Linux raspberrypi 6.6.74+rpt-rpi-v8 #1 SMP PREEMPT Debian 1:6.6.74-1+rpt1 (2025-01-27) aarch64 GNU/Linux
Pi@raspberrypi:~ $ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description: Debian GNU/Linux 12 (bookworm)
Release: 12
Codename: bookworm
Pi@raspberrypi:~ $ apt-cache policy piaware
piaware:
Installed: 10.0
Candidate: 10.0
Version table:
*** 10.0 100
100 /var/lib/dpkg/status
Pi@raspberrypi:~ $ apt-cache policy dump1090-fa
dump1090-fa:
Installed: 10.0
Candidate: 10.0
Version table:
*** 10.0 100
(1) Wrote piaware SD card image to microSD card using Win32DiskImager
(2) Opened drive letter of card writer. This opened /boot
folder. In this folder created a blank file named ssh
(3) In same /boot
folder, opened file piaware-config.txt
(4) In file piaware-config.txt
, scrolled down and added WiFi credentials in following lines:
(replaced âMyWiFiNetworkâ and âs3cr3tâ by my WiFi credentials)
wireless-ssid MyWifiNetwork
wireless-password s3cr3t
(5) Scrolled to bottom of file piaware-config.txt
, and below last line added following details
# Additional settings can be added below.
feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
rtlsdr-device-index 00001090
uat-receiver-type sdr
uat-sdr-device driver=rtlsdr,serial=00000978
(6) Saved file, ejected microSD card from Windows Desktop, slipped microSD card in RPi, and powered up.
(7) IMPORTANT: After first boot, checked current IP of RPi from router. It may be efferent from what it used to be before re-imaging
(8) Connected to RPi by SSH using IP found from router (item (7) above), and logged-in using following
- username: pi
- password: flightaware
(9) Configured WiFi STATIC network using Network Manager
sudo nmtui
Click on Screenshot to See Larger Size
Thankyou so much abcd567) will do this over night
