I enjoy listening to Live ATC at times, but the controllers’ commands are so quick and short that it’s hard to decipher most of them.
I just flew ATL-SFO, and as the plane’s descent approached the East Bay cities, it performed a couple of, to me, really sharp S-curves. I assume this was a form of vectoring, to delay the landing time.
My question is: What would ATC likely say to the pilot to get him to perform this maneuver. Maybe there is a code word for this??
Anyone?
Make a series of “S” turns for spacing, etc.
If the aircraft was close to the airport, than S turns for spacing, etc, would work. This is really not what the pilots or the tower controllers really want to do…but rather than send an aircraft around, you do what you need to do.
Further away from the airport, with plenty of airspace and altitude to drive planes around, the radar (approach control or Center) controller could give “vectors for spacing”. A fifteen degree turn off the current heading for a certain amount of time, then a turn back to intercept the original flight path. Controllers build space between aircraft this way, by varying the amount of time the aircraft is kept on the new heading.
The rules and phraseology are in the 7110.65:
Loud and clear. Thanks.
Adraenyse, what country do you fly in?
In the US, the maneuver you describe is called a “360”, as in, “make a three sixty for spacing” or whatever reason.
I’d also be interested to learn more about your airport and the traffic mix. Must be interesting to combine gliders with conventional aircraft.
And sometimes you’ll run across a controller with a sense of humor. This actually happened to me while flying a light twin into KATL – yes, THAT Atlanta airport, back in the 80’s. I was number three for landing, sandwiched in between two rather large airliners. Kept my speed up to 140K which was about 40K over usual approach speed. Thought I was doing great until ATC asked me to “keep my speed up unless I wanted to be a hood ornament on the L1011 behind me!” I did – landed rather long, and even got a “nice job” from the L1011. ![]()
