Anyone working with the new x86 Raspbian
Confirmed piaware builds and works OK on Ubuntu 18.04 by using package-bionic.
abcd@ubuntu:~$ cat /etc/os-release
NAME="Ubuntu"
VERSION="18.04.2 LTS (Bionic Beaver)"
abcd@ubuntu:~/piaware_builder$ ./sensible-build.sh bionic
abcd@ubuntu:~$ ls piaware_builder
bionic       package-bionic                                README.md
changelog    piaware_3.7.1~ubuntu1804+1_amd64.buildinfo    sensible-build.sh
common       piaware_3.7.1~ubuntu1804+1_amd64.changes      stretch
Jenkinsfile  piaware_3.7.1~ubuntu1804+1_amd64.deb          wheezy
jessie       piaware-dbgsym_3.7.1~ubuntu1804+1_amd64.ddeb  xenial
   Active: active (running) since Tue 2019-10-01 14:16:44 EDT; 1min 48s ago
 Main PID: 2902 (piaware)
    Tasks: 4 (limit: 4659)
           β”œβ”€2902 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
           β”œβ”€2915 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,l
           └─2918 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.xxx --lon -79.xxx
Oct 01 14:16:48 ubuntu piaware[2902]: mlat-client(2915): fa-mlat-client 0.2.10 starting up
Oct 01 14:16:48 ubuntu piaware[2902]: mlat-client(2915): Using UDP transport to 70.42.6.197 port 6553
Oct 01 14:16:48 ubuntu piaware[2902]: mlat-client(2915): Listening for Beast-format results connection on port 30105
Oct 01 14:16:48 ubuntu piaware[2902]: mlat-client(2915): Listening for Extended Basestation-format results connection on port 30106
Oct 01 14:16:48 ubuntu piaware[2902]: mlat-client(2915): Input connected to localhost:30005
Oct 01 14:16:48 ubuntu piaware[2902]: mlat-client(2915): Input format changed to BEAST, 12MHz clock
Oct 01 14:16:49 ubuntu piaware[2902]: mlat-client(2915): Beast-format results connection with 127.0.0.1:30104: connection established
Oct 01 14:16:49 ubuntu piaware[2902]: piaware received a message from dump1090-mutab!
Oct 01 14:16:55 ubuntu piaware[2902]: piaware has successfully sent several msgs to FlightAware!
Oct 01 14:17:19 ubuntu piaware[2902]: 31 msgs recv'd from dump1090-mutab; 31 msgs sent to FlightAware
The ubuntu targets are semi-maintained, in that they worked at one point but I don’t test them every release.
I’ve been doing some rework of our build infrastructure and at least testing the build process on Ubuntu is somewhat more feasible now; but it’s likely that we’d only look at supporting LTS releases to begin with.
Has anyone tried this to run Piaware?
The ARM Linux Laptop Starting At $99 USD
