Anyone working with the new x86 Raspbian
Ubuntu was the only Linux distro I used for over a decade. I have installed it as dual boot (Windows/Ubuntu) on my desktop.
However after trying Debian last year, I found it is much better and faster than Ubuntu, and stopped Using Ubuntu. Now my default x64 distro is Debian (through VM). I still have Ubuntu as 2nd boot option, but rarely use it now.
It should fall back to the compiled-in messages (i.e. the untranslated ones), in theory.
Happy Aniversary
I downloaded it and successfully installed it as a working live USB installation with Rufus.
What do you mean by ā€œitā€? Can you please give the name?
Hi
I’ve noticed that MLAT never worked.
Below the output of systemctl status piaware:
ā— piaware.service - FlightAware ADS-B uploader
Active: active (running) since Tue 2019-10-01 09:52:44 -03; 16min ago
Main PID: 1491 (piaware)
Tasks: 3 (limit: 4915)
Memory: 19.2M
ā”œā”€1491 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
└─1638 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat -22.958 --lon -43.196
Oct 01 10:08:05 allex-Aspire sudo[3364]: piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/usr/bin/netstat --program --tcp --wide --all --numeric
Oct 01 10:08:05 allex-Aspire sudo[3364]: pam_unix(sudo:session): session opened for user root by (uid=0)
Oct 01 10:08:05 allex-Aspire piaware[1491]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:3010
Oct 01 10:08:05 allex-Aspire piaware[1491]: mlat-client(3366): Fatal Python error: initfsencoding: Unable to get the locale encoding
Oct 01 10:08:05 allex-Aspire piaware[1491]: mlat-client(3366): ImportError: invalid flags 1566320683 in ā€˜encodings’
Oct 01 10:08:05 allex-Aspire piaware[1491]: mlat-client(3366): Current thread 0x00007fb7973d2740 (most recent call first):
Oct 01 10:08:05 allex-Aspire sudo[3364]: pam_unix(sudo:session): session closed for user root
Oct 01 10:08:05 allex-Aspire piaware[1491]: got EOF from multilateration client
Oct 01 10:08:05 allex-Aspire piaware[1491]: fa-mlat-client exited with SIG SIGABRT
Oct 01 10:08:19 allex-Aspire piaware[1491]: 190 msgs recv’d from dump1090-mutab (102 in last 5m); 181 msgs sent to FlightAware
Still a language/locale issue ?
python problems.
cxFreeze incompatibility i believe.
You can try this: Piaware v 3.7.1 on Debian 10.0 (Buster) amd64 / Intel PC - #52 by abcd567
You compiled piaware, yes?
Yes, I compiled according abcd567 but, for bionic.
Do I have to follow your link for Freeze ?
It’s just about replacing the cxFreeze folder , not about the version.
I’d just use
./sensible-build.sh stretch
cd package-stretch
then replace the cxFreeze folder and compile/install.
OK. I’ll try that.
Yes. Please see below:
It seems to point the same link from wiedehopf, started by you.
I’ll work on that.
Done !
MLAT working now!
Thanks to @wiedehopf and @abcd567
You are the best !
P.S: Just to remember replace stretch by bionic for users with Ubuntu 18.04 or 19.04 (my case)
:+1: :+1: :+1:
True, but the thread was for Debian 10 (Buster), not for Ubuntu. That is why I mentioned change to stretch.
For Ubuntu sure stretch does not apply and should be changed to bionic
stretch is the most current version, while the Ubuntu sensible build targets are too old.
If i remember correctly there are some problems using the Ubuntu build targets.
Yes, for sure !
Ubuntu bionic is stretch based
Ubuntu disco dingo is buster based
List of releases
Current
Version Code name Docs Release End of Standard Support End of Life
Ubuntu 19.04 Disco Dingo Release Notes April 18, 2019 January, 2020 January, 2020
Ubuntu 18.04.3 LTS Bionic Beaver Changes August 8, 2019 April 2023 April 2028
Ubuntu 18.04.2 LTS Bionic Beaver Changes February 15, 2019 April 2023 April 2028
Ubuntu 18.04.1 LTS Bionic Beaver Changes July 26, 2018 April 2023 April 2028
Ubuntu 18.04 LTS Bionic Beaver Release Notes April 26, 2018 April 2023 April 2028
Ubuntu 16.04.6 LTS Xenial Xerus Changes February 28, 2019 April 2021 April 2024
Ubuntu 16.04.5 LTS Xenial Xerus Changes August 2, 2018 April 2021 April 2024
Ubuntu 16.04.4 LTS Xenial Xerus Changes March 1, 2018 April 2021 April 2024
Ubuntu 16.04.3 LTS Xenial Xerus Changes August 3, 2017 April 2021 April 2024
Ubuntu 16.04.2 LTS Xenial Xerus Changes February 16, 2017 April 2021 April 2024
Ubuntu 16.04.1 LTS Xenial Xerus Changes July 21, 2016 April 2021 April 2024
Ubuntu 16.04 LTS Xenial Xerus Release Notes April 21, 2016 April 2021 April 2024
Ubuntu 14.04.6 LTS Trusty Tahr Changes March 7, 2019 April 2019 April 2022
Ubuntu 14.04.5 LTS Trusty Tahr Changes August 4, 2016 April 2019 April 2022
Ubuntu 14.04.4 LTS Trusty Tahr Changes February 18, 2016 HWE August 2016 April 2022
Ubuntu 14.04.3 LTS Trusty Tahr Changes August 6, 2015 HWE August 2016 April 2022
Ubuntu 14.04.2 LTS Trusty Tahr Changes February 20, 2015 HWE August 2016 April 2022
Ubuntu 14.04.1 LTS Trusty Tahr Changes July 24, 2014 April 2019 April 2022
Ubuntu 14.04 LTS Trusty Tahr Release Notes April 17, 2014 April 2019 April 2022
You can find the Debian version on which your Ubuntu version is based in the file: /etc/debian_version
From 10.04 up to 19.04:
Ubuntu            Debian
19.04  disco      buster  / sid   - 10
18.10  cosmic     buster  / sid
18.04  bionic     buster  / sid
17.10  artful     stretch / sid   - 9
17.04  zesty      stretch / sid
16.10  yakkety    stretch / sid
16.04  xenial     stretch / sid
15.10  wily       jessie  / sid   - 8
15.04  vivid      jessie  / sid
14.10  utopic     jessie  / sid
14.04  trusty     jessie  / sid
13.10  saucy      wheezy  / sid   - 7
13.04  raring     wheezy  / sid
12.10  quantal    wheezy  / sid
12.04  precise    wheezy  / sid
11.10  oneiric    wheezy  / sid
11.04  natty      squeeze / sid   - 6
10.10  maverick   squeeze / sid
10.04  lucid      squeeze / sid
sid is the development distribution of Debian
Yeah but the sensible-build stuff for Ubuntu isn’t maintained properly.
stretch is.
And as it’s stretch based, it works.
Pretty sure he used stretch as i wrote and it worked.
(not saying using sensible-build bionic wouldn’t have worked, but why use something that’s not maintained?)
Are you sure?
@obj can confirm.
