I loaded up a second Pi4B and installed MODESDECO2 with abcd567 scripts and then installed VRS for their better quality mapping. This Pi I am not sharing my data with since it is used for antenna experiments and tests that’s why I did not use Pi aware image. Is there a better ADSB/MODE S decoder to use or is MODESDECO2 good enough?
I just reimaged and installed his scripts and all is working better. I have more cheap Banggood Chinese antennas on the way to test out. the one I am using right now is the 6 dollar PCB version. I have the 1/2 wave and the amplified one ordered and shipped.
I have 1 main FA antenna
can i feed 2 pi4 with splitter either picture setup
or will i run into interference, over or back voltage ?
Bangs pops or smoke ?
In the past I experimented with a few home built “ADSB CANTENNAS”. My Piaaware uses a Flightaware 1090 Antenna and a 978 Cantenna. This set up I decided to try to see what performance that the cheap Chinese ADSB antennas found on Banggood, Ali or E-Bay has to offer and trying to stay under 20 bucks per antenna. I am running a Pi4B, Flightaware Blue ADSB Dongle, 65 foot of low loss RG58 Cable. Yes I know RG58 is not that great but it was a steal at 22 dollars a roll with SMA connectors already installed. So far the cheap 6 dollar antenna (PC-Board ADSB) inside of a PVC enclosure actually works pretty good.
