Antenna Testing, Home Built, simple J-Poles
Aim:
To save you reading this test: – build a simple ¼ wave spider as I found that 95 times out of a 100 it will outperform a simple J-Pole.
The first set of results which were for ¼ Wave antenni and be found here. “Antenna Testing, Home Built, ¼ waves”; Antenna Testing, Home Built , ¼ waves.
As before, before installing the Flight Aware Rx on the outside of my home I wanted to check which type of antenna gave the best reception. I would like more gain than a ¼ wave (no gain) but I have a small 80m-110m wooded hill one mile (2020m) to the east of me. So the two antenna types I selected to for testing where ¼ waves and J-poles as they appear to be dimensionally stable, so should easy to trim and be suitable for mounting in the open air. Both have relatively high take-off elevations, so the effect of the hill will be minimised. Coax Colinear antenni have more variables in their construction, without test equipment the performance of a colinear would be a shot in the dark, for me at least.
Dates:
Simple J poles from 16 March 2018 to
Links:
Calculator:
Books:
“The Radio Communication Handbook” by RSGB ISBN: 1905086083,9781905086085 Chapter 16 “Practical VHF Antennas”.
Tests J-pole:
All tests were performed with the Rx in the same location and the data for each test was collected over 24 hour period, using both the Mode S Mixer data capture application and the Flight Aware flight counters.
I have included the results of a Coke cantenna as a “Control”, so that you can compare the coverage of your standard Coke can cantenna with the J Pole designs sown below. The Coke can cantenna is a great reference point, as we can all build identical antanni and compare our results no matter which country we live in.
In order to ensure all the measurements of the elements where repeatable, the elements were measured from the “centre of the bend” using an engineers steel rule. A pair of vernier callipers were used to measure the diameter of the brass rod, length of the stub and the separation of the two elements.
Tuning the J Pole without electronic test equipment needs to be performed by trimming the elements 1.0mm - 0.2mm each day and then recording the aircraft contacts for that day: a slow process. I limited the changes to one each day so that I could identify the effect of each individual change.
The final element lengths were calculated using a spreadsheet. (The most online calculators don’t provide enough resolution on the stub length). Searching the web revealed the separation to go for was between 6mm and 8mm and the feed point 6mm and 10mm
The diameter of the rod: 3.2mm
Element separation : 6.0mm (base) – 6.3mm (tip)
Feed point : 7mm
BEST RESULTS FROM:
198.8mm * 6mm * 66.5mm : TEST J16
198.1mm * 6mm * 66.2mm : TEST J19
The line below shows the difference in the measured length (slightly diagonal) versus the “true vertical length”. It was not practical to measure the “true length” with a steel rule or calliper, thus the measurement was taken from the central bend to the element tip. I found I could see the difference in coverage if the elements changed by 0.1mm - 0.2mm.
vertical length = Sqr( (67.5mm)^2 - (3mm)^2 ) = 67.23mm
- J1, J-pole, copper wire, 207mm x 69mm , feed 10mm
- J2, J-pole, copper wire , 207mm x 69mm, feed 7mm
- J3, J-pole, copper wire , 201mm x 68mm, feed 7mm
- J4, J-pole, brass rod, 207mm x 68mm
- J5, J-pole, brass rod, 205mm x 68mm
- J6, J-pole, brass rod, 204mm x 68mm
- J7, J-pole, brass rod, 203mm x 68mm
- J8, J-pole, brass rod, 203mm x 66.8mm
- J9, J-pole, brass rod, 202mm x 66.8mm
- J10, J-pole, brass rod, 201mm x 66.8mm
- J11, J-pole, brass rod, 200.5mm x 66.8mm
- J12, J-pole, brass rod, 200.5mm x 66.5mm
- J12, J-pole, brass rod, 200mm x 66.5mm
- J12, J-pole, brass rod, 199.5mm x 66.5mm
- J12, J-pole, brass rod, 199.2mm x 66.5mm
- J12, J-pole, brass rod, 198.8mm x 66.5mm
- J12, J-pole, brass rod, 198.5mm x 66.5mm
- J12, J-pole, brass rod, 198.1mm x 66.2mm
- J12, J-pole, brass rod, 198.0mm x 66.2mm
- J12, J-pole, brass rod, 198.0mm x 66.1mm
- J12, J-pole, brass rod, 198.0mm x 66.0mm
- J12, J-pole, brass rod, 197.8mm x 66.0mm
- J12, J-pole, brass rod, 198.5mm x 66.0mm
Test Equipment:
Same as used in, Antenna Testing, Home Built , ¼ waves
Rx: Noolec SMArt, Aluminum Enclosure, 0.5PPM, SMA conector (2017)
Filter: 1090Mhz surface mount, 50 Ohm, SMA connector Passband: 1086 ~ 1094 MHz
Processor: Raspberry Pi 3
Operating Sys: PiAware 3.5.3 with Mode S Mixer
USB cable: Lindy 100mm from Rx to the processor
Arial main cable: 1000mm double screened satellite cable, 75 Ohm
Arial pig tail: Lindy 100mm coax, SMA to F type panle mount
Arial connector: F Type 75 Ohm
Data comms: Pi Ethernet to the power line (Pi WiFi diabled) .
Location: Inside concrete block built garage, tile roof, arial 2m above floor
Ground 97.5m Above sea level
Note: There is only one impedance step change in the Rx line 75 Ohm to 50Ohm, which occurs at the join between the satelite cable the pig tail. Not an significant issue as the rig is not a transmitter.
The test location was the same for all tests The location is not ideal thus the results of one anttena should only be compared to results of another antenna in this test.
Results J Pole:
The J-Poles take a great deal of time to tune and only when tuned do they perform better than a basic ¼ wave. 1.6mm copper wire was found to be too flexible to form a stable J-Pole, due to the tension in the coax connections. 3.2mm brass rod was found to be easily worked and did form a dimensionally stable J-Pole. A variation in length of 0.1mm is all that it took to take the j-pole for good to average coverage.
Conclusion:
Without the use of electronic test equipment, it is possible for a home builder to construct ¼ wave ground plan antenni, which can be relied upon to give good or acceptable coverage. The J-Pole is likely to give worse coverage than a ¼ wave antenna unless it is tuned with electronic test equipment or if no test equipment is available, painstakingly slowly by test, trim test.
The recommendation is for a new home builder to first build a ¼ wave ground plane “spider”, using accurate measurements and good construction techniques, as this can be relied upon to give good coverage.
After 3 weeks of tuning my simple J-Pole I found it performed slightly better than my best ¼ wave (which was never turned up!). I suspect the J-Pole will go off tune as soon as it is placed in a PVC pipe radome.
Control Test:
¼ wave Coke Cantenna /
garage /
13-16/03/2018 /
Tues 20:00 – Friday 20:00
Arial element length: 68.5mm x 1.0mm brass wire
Diameter: it’s a coke can
Height: 69mm
Connector: F Type
J-Pole Tests 1.6mm copper
Tests J1 → J3
Initial designs calculated using the M0UKD online calculator.
The initial tests were performed using 1.6mm copper wire. Copper wire of this diameter was found to be too flexible as the gap between the elements changes if the tension on the coax cable changed. 3.2mm brass rod was found to be more physical ridge and stable thus enabling measurements and tests to be repeatable.
J Pole 3mm Brass rod
Tests J4→J23
3.2mm brass rod bent around a 6mm drill to form a 6mm space between the “Inside” edges of the vertical elements.
Satelite coax attached to elements using the innards of a main terminal box connector. The nards where removed and then cut in half to form the two connectors. Coax cable comes in from the top.
Top of the terminal is 7mm from the “Inside” edge of the bottom bend.
The whole antenna is isolated via a plastic terminal connector (with all the metal internal connectors removed) and a wooden dowel.
Test J6:
garage /
2018-03-19 19:54:09
to Tuesday 20th (22 hours 15 minutes)
Change: cut 1mm from main.
204mm * 6mm * 68mm and
feed 7mm from base
3.2 mm Brass rod
velocity factor = 0.990
Total messages / min : 8.390 x 10^3
Total messages: 11200,000
Max distance: 113 n miles (Azi 110 deg)
Max dis 2nd lobe: 100n miles (Azi 200 deg)
Test J10:
garage /
2018-03-23 18:39:05
to Saturday (1 day 37 minutes)
201mm * 6mm * 66.8mm and
feed 7mm from base
3.2 mm Brass rod
Total messages / min : 8.182 x 10^3
Total messages: 12100,000
Max distance: 108 n miles (Azi 120deg)
Max dis 2nd lobe: 97n miles (Azi 220deg)
Test J16:
garage /
29/03/2018 /
to Friday (1 day 1 hours 25 minute) “Good Friday”
Change: cut .4mm from main.
198.8mm * 6mm * 66.5mm and
feed 7mm from base
3.2 mm Brass rod
Total messages / min : 12.177 x 10^3
Total messages: 18571,000
Max distance: 134 n miles (Azi 120deg)
Max dis 2nd lobe: 118n miles (Azi 210deg)
Test J19:
garage /
1/04/2018 /
to Monday (24 hours 1 minute) Easter Monday
Change: cut 0.4mm from main.
198.1mm * 6mm * 66.2mm and
feed 7mm from base
3.2 mm Brass rod
Total messages / min : 11.519 x 10^3
Total messages: 16600,000
Max distance: 135 n miles (Azi 120deg)
Max dis 2nd lobe: 126n miles (Azi 200deg)
Max dis 3rd lobe: 109n miles (Azi 280deg)
