Hi,
Evrything was working perfectly and after trying to use my RTL-SDR dongle v.3 with DVB-T (unsuccessfully), it stopped working and now I have an error message and no planes on the map:
Problem fetching data from dump1090.
AJAX call failed (error). Maybe dump1090 is no longer running?
The displayed map data will be out of date.
After digging around, I think there is a problem with lighttpd which doesn’t want to start. Here is the journal:
Jan 27 20:24:28 Romanopi systemd[1]: Starting Lighttpd Daemon…
Jan 27 20:24:29 Romanopi lighttpd[4142]: 2021-01-27 20:24:28: (configfile.c.1296) source: /etc/lighttpd/conf-enabled/89-dump1090-fa.conf line: 75 pos: 1 parser failed somehow near here: (EOL)
Jan 27 20:24:29 Romanopi lighttpd[4142]: 2021-01-27 20:24:28: (configfile.c.1296) source: /etc/lighttpd/lighttpd.conf line: 47 pos: 15 parser failed somehow near here: (EOL)
Jan 27 20:24:29 Romanopi systemd[1]: lighttpd.service: Control process exited, code=exited, status=255/EXCEPTION
Jan 27 20:24:29 Romanopi systemd[1]: lighttpd.service: Failed with result ‘exit-code’.
Jan 27 20:24:29 Romanopi systemd[1]: Failed to start Lighttpd Daemon.
Jan 27 20:24:29 Romanopi systemd[1]: lighttpd.service: Service RestartSec=100ms expired, scheduling restart.
Jan 27 20:24:29 Romanopi systemd[1]: lighttpd.service: Scheduled restart job, restart counter is at 5.
Jan 27 20:24:29 Romanopi systemd[1]: Stopped Lighttpd Daemon.
Jan 27 20:24:29 Romanopi systemd[1]: lighttpd.service: Start request repeated too quickly.
Although I got it to start by removing the 89-dump1090-fa.conf file, it didn’t solve the issue.
Finally, here is the piaware status :
PiAware master process (piaware) is running with pid 6163.
PiAware ADS-B client (faup1090) is running with pid 6200.
Local ADS-B receiver (dump1090-fa) is running with pid 6128.
dump1090-fa (pid 6128) is listening for ES connections on port 30005.
Your feeder ID is 34465f58-06a3-4141-88b2-61c43fe971a4 (from /var/cache/piaware/feeder_id)
I don’t know why ADS-B UAT client (faup978) and mlat client (fa-mlat-client) are not running, if it is normal or not and how to update the configuration settings.
After having digged around quite a bit in this forum, I decided to ask you directly if someone could help me. Please.
Best regards.
Romain
