Having similar outcomes on site 101026. I’ve dedicated a pi with Orange FA receiver and 978 antenna next to my 1090.
I have a few unicorns out there at 200+ miles …
I turned down gain last night to 30. I haven’t taken the next steps yet in tuning my gains …not exactly a lot of signals out there.
My next steps will be dictated by the next several weeks…my site is rather new…I’m operating in an attic and have moved my radios and Pi’s into conditioned space to drop the heat.
I don’t know how much 978 traffic we will have around DC…
We’re not quite ready to officially support two receivers on one Raspberry Pi yet. We’re not pushing 3.7.1 updates either. If you want to upgrade go to your stats page, click the gear icon in the top right of the page and send the device command “Upgrade and restart PiAware”.
Version that supports two receivers is already out, it’s 3.7.1
I am running two receivers now. You will probably need powered USB hub or you may lose performance with two dongles.
Is there an easy way to see how many flights my 978 antenna is picking up? I’m have two receivers on one Pi right now. Do I need to request a separate site so I can see separate results from my 1090 antenna?
Installed the flightaware 978 antenna yesterday and have two contacts already:
Guess the antenna works! Maybe a fluke that two aircraft (or the same one twice) just happened to be in the area, will see what shows up next few days.
Distance is right for GFK, however I wasn’t present at the time to see the aircraft on the map. Could be dual mode, at least I am picking up the 978 side.
Mine is not well optimized right now. It’s only up about 20ft on a mast beside the house roof and trees block the horizon somewhat. Been planning a trip up the tower to install the antenna and feedline for 978 but never get a spare moment or weather is an issue (40mph winds today). I am thinking a pre-amp would help too so might set something up before final install. I am using the light blue filter as well. Afraid the broadband pre-amp I have might cause more noise even with the filter. Will have to try and see how it works I guess.
Thank you @wiedehopf
Yes I now see Uptronics has a 978 pre-amp, didn’t see that before. Already have the ceramic uptronics pre-amp/filter on my 1090 line on the tower. Works well.
Have problem signals at 912-920Mhz (cell?) and lower down at 870MHz, local control channel for Motorola trunking system. Might try to build some “medium” Q notch filters for these using feedline stubs… maybe then the broadband pre-amp would be ok. Lots of fine tuning required though. So easy just to purchase one.
978 Results 30 Days
The 978 system has been running for six weeks and as the spring flying weather improves, and the 1/1/2020 ADS-B deadline approaches the 978 traffic builds.
On a nice weekend 100 to 200 airplanes show up, almost all within 100 miles. Trailing 30 day count:
