I’m using this API (AirlineFlightSchedules) to get scheduled flights from specific and unique airport between two dates (start date and end date).
In the result set, I noticed that have too many flights, due to some stop counts (I need all unique flights arrivals on Airport M, and not flights from Airport A, which stops on Airport B then go to the Airport M. Just wanna know flight arrivals from Airport B to Airport M).
Do you guys know if there is another API to get this, or if I have to implement this on my side? Or if there is a specific multiple API calls on different endpoints to achieve this?
Unfortunately there isn’t another endpoint within FlightXML2 that can do this due to the way we handle multi-leg flights. There would have to be some implementation on your side to filter out the unwanted results.
You might be interested to take a look at the V4 commands within GET airports which I have linked below as there has been some improvements as to what can be called in regards to non-stop/one-stop flights.
