Hello,
I’ve been flightfeeding for quite some time already and I discovered that I had my Gain settings incorrect.
Thanks to @wiedehopf and @abcd567 i was able to set more correct gain settings.
Now I’m wondering if you have any other advice in regard to the setup ?
I have a challenging environment, I have 2 feeders, opposite of each other on the 3rd floor of an appartment building. Antenna’s are mounted inside the building due to restrictions of the home owners association. I’ve uploaded 2 screenshots, both setups are shown.
I use Raspberry Pi’s, blue flightware prosticks plus, Flightaware 1090MHZ filters and I have tje FA antenna, 1 with 1 meter COAX, the other has 3 meter coax connection ( both SMA to N connectors).
Looking forward to your comments in order to learn something, maybe I should adjust gain up or down ?
