3.7.0.1 978 Only Questions
What do I change the null to? True?
you have to get a key,
don’t post your key. Remove the image.
You need to put the key between double quotes were the null is.
// is a comment so is ignored. That is why it is in blue.
  • understand and the picture has been removed.*
The extra map layers are cool. I love those options.
Jon, thanks for pointing this out and the help with the range rings.
How about the 1090 side of the maps?
same thing
sudo vi /usr/share/dump1090-fa/html/config.js
or sudo nano /usr/share/dump1090-fa/html/config.js
I think you have to restart lighttpd and/or dump1090-fa too.
I can get in and edit the file and save but the changes are not showing up under the 1090 side. I did a reboot and no luck.
ctrl F5 or shift reload (I didn’t need to restart anything).
It is just a browser refresh.
I completely forgot about the F5 refresh. One more question when the option is selected the “true” turns to yellow I would assume that this is now turned on?
Thanks Jon, I appreciate it.
Glad it works.
The colours are a function of nano.
I don’t normally use it. I use vi except on one device that doesn’t like it(when I do a paste).
You would need to look at the notes for nano.
