Worth upgrading from piaware 3.6.3 to 3.8.1?
OK, very good. May be worth adding to your instructions, or at least make it more clear that Step 6 is only required when using both dump1090-fa & dump978-fa. You do say this, but it may not be clear to dummies like me.
OK, I see that the original value of the device index was 0, not 1000. I changed it back to 0. Seems to be working.
Again, many thanks!!!
You made a mistake to follow above instructions, which are under following heading.
6 - Configuration for using both dump1090-fa & dump978-fa
It does not apply to your install as you did NOT install dump978-fa.
No need to add any further instructions, as it is very clear from the heading of the item when to use it.
Agreed. OK, many thanks again!!
I do notice somewhat better results going from piaware v3.6.3 on Debian 9 to piaware v3.8.1 on Debian 10.
Congratulations that you succeeded in upgrading your system (OS+piaware+dump1090-fa) to their latest versions. :+1:
I could have NEVER done it without your EXCELLENT instructions!!! Every time I go through the exercise of building piaware from source, it’s a great learning experience. I guess I’ll be doing this about once a year, which means I’ll be bugging you for the latest build instructions on an annual basis!!
Well @obj possibly can shed some light on this.
I still have the old VM, so I can compare the two. But I will be sticking w/ the new version.
There have been two major changes. May be improvement is combination of both.
  1. Your OS has been upgraded to 2020-02-12-rpd-x86-buster.iso (which is based on Debian Buster 10.3)
  2. Piaware+dump1090-fa upgraded to v3.8.1
top - 08:24:27 up  1:47,  3 users,  load average: 0.44, 0.50, 0.48
Tasks: 140 total,   1 running, 139 sleeping,   0 stopped,   0 zombie
%Cpu(s): 18.4 us, 16.7 sy,  0.0 ni, 64.3 id,  0.0 wa,  0.0 hi,  0.7 si,  0.0 st
MiB Mem :    431.3 total,     12.6 free,    139.2 used,    279.4 buff/cache
MiB Swap:    610.0 total,    610.0 free,      0.0 used.    275.5 avail Mem
  PID USER      PR  NI    VIRT    RES    SHR S  %CPU  %MEM     TIME+ COMMAND
20379 dump1090  15  -5   29348   7656   3120 S  23.5   1.7   9:13.43 dump1090-fa
23349 piaware   20   0   17072   9392   5864 S   1.3   2.1   0:18.43 fa-mlat-client
    9 root      20   0       0      0      0 S   1.0   0.0   0:20.08 ksoftirqd/0
  606 www-data  20   0   10112   5420   4456 S   1.0   1.2   0:36.20 lighttpd
23293 piaware   20   0   27592  12312   6976 S   1.0   2.8   0:15.07 piaware
31581 pi        20   0   10644   3736   3220 R   1.0   0.8   0:00.21 top
   10 root      20   0       0      0      0 I   0.7   0.0   0:25.98 rcu_sched
 1143 pi        20   0  144508  30116  24780 S   0.3   6.8   0:09.58 lxpanel
 2551 pi        20   0   12440   4660   3816 S   0.3   1.1   0:02.06 sshd
23312 root      20   0       0      0      0 I   0.3   0.0   0:00.26 kworker/u2:1-events_unbound
23346 piaware   20   0    3948   2260   2072 S   0.3   0.5   0:04.80 faup1090
    1 root      20   0   17008   8880   7148 S   0.0   2.0   0:14.40 systemd
    2 root      20   0       0      0      0 S   0.0   0.0   0:00.03 kthreadd
Question: Does sending feeder output to addition sites (e.g. adsbexchange, using their ā€œscript methodā€) impose significant performance overhead?
I have it running on a Raspberry 3B and feed overall six sites. I cannot identify any performance issues.
There were 160 commits between 3.6.3 and 3.8.1: Comparing v3.6.3...v3.8.1 Ā· flightaware/dump1090 Ā· GitHub
So yes I’d expect them to behave differently.
Thanks for the info, @obj. 160 commits in approx 16 months, so about 10 commits per month. Out of those, I can believe there’s at least one or two major enhancements ;-).
Good to know, @foxhunter . Given that I have mine running on a VM on an 11 year old Netbook with an Intel Atom N450 1.66GHz single core CPU (remember those?), I think I’ll keep the overhead to a minimum. So I won’t be adding any additional feeders.
Most of the feeder are taking the data delivered by your dump1090 instance. So the CPU load is not increasing that much.
Just checked it. While dump1090 is currently using 15-20% CPU, the other feeders and clients are at 1-3% each.
@foxhunter Thanks! Appreciate the info. Like I said, my setup is running on a very wimpy platform. I find it endlessly fascinating that it works at all. I will probably keep mine as is. But if I ever upgrade to an RPi, I will probably add some additional feeder(s).
There are people running it on a Pi Zero which is a single core CPU with 512 MB RAM
OK! Good to know. Thanks.
OK, I finally added adsbexchange to my feeder using the script method on my FA feeder. As you said, there is negligible overhead. It’s working fine!! Running it in a Linux virtual machine w/ 512MB memory on an Asus Netbook Eee PC 1005-PEB ā€œnetbookā€ (circa 2009) with an Intel Atom N450 CPU and 2GB memory that is running Windows 10 ā€œStarter Editionā€ (32-bit).
What i have identified is that ADSBx causes more traffic via Internet than FR24 or FA feeding.
Just in case you have a metered connection. If not, you do not need to care.about
