Version 3.7.0 of dump1090-fa & Piaware
ssh.txt didn’t work for me
Valid file names for enabling SSH:
  • ssh
  • ssh.txt
  • SSH
  • SSH.txt
Maybe the file extension was hidden by windows?
That would make the actual filename ssh.txt.txt
(Or the other options were introduced somehwere along the way)
That’s one of the first things that I un-hide on Windows. So annoying.
But this was a year ago when I imaged last my SD card, so things might have changed.
This has happened with me once when “show extension for known file type” was unchecked in “folder options”. Since then I started using extensionless version i.e. ssh or SSH, just in case. :slight_smile:
This is why I dumped *indows and only use *nix :smiley:
Cheers!
LB
Piaware 3.7.0 + dump1090-fa 3.7.0 on OrangePi PC / Armbian 5.75 (Stretch)
pi@orangepipc:~/piaware_builder$ sudo cat /var/log/piaware.log
Apr  7 23:34:16 localhost piaware[6641]: creating pidfile /run/piaware/piaware.pid
Apr  7 23:34:16 localhost piaware[6641]: ****************************************************
Apr  7 23:34:16 localhost piaware[6641]: piaware version 3.7.0 is running, process ID 6641
Apr  7 23:34:16 localhost piaware[6641]: your system info is: Linux orangepipc 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:0
rmv7l GNU/Linux
Apr  7 23:34:18 localhost piaware[6641]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Apr  7 23:34:18 localhost piaware[6641]: Connection with adept server at piaware.flightaware.com/1200 established
Apr  7 23:34:18 localhost piaware[6641]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Apr  7 23:34:18 localhost piaware[6641]: FlightAware server certificate validated
Apr  7 23:34:18 localhost piaware[6641]: encrypted session established with FlightAware
Apr  7 23:34:19 localhost piaware[6641]: adept reported location: 43.5xxxx, -79.6xxxx, xxxft AMSL
Apr  7 23:34:19 localhost piaware[6641]: Receiver location changed, restarting dump1090 and skyview978
Apr  7 23:34:19 localhost piaware[6641]: attempting to restart dump1090..
Apr  7 23:34:19 localhost piaware[6641]: attempting to restart dump1090-fa using 'systemctl --no-block try-restart du
ce < /dev/null'...
Apr  7 23:34:19 localhost piaware[6641]: dump1090 restart appears to have been successful
Apr  7 23:34:19 localhost piaware[6641]: attempting to restart skyview978..
Apr  7 23:34:19 localhost piaware[6641]: attempting to restart skyview978 using 'systemctl --no-block try-restart sky
 < /dev/null'...
Apr  7 23:34:19 localhost piaware[6641]: skyview978 restart appears to have been successful
Apr  7 23:34:19 localhost piaware[6641]: logged in to FlightAware as user abcd567
Apr  7 23:34:19 localhost piaware[6641]: my feeder ID is xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
Apr  7 23:34:19 localhost piaware[6641]: site statistics URL: https://flightaware.com/adsb/stats/user/abcd567#stats-6396
Apr  7 23:34:19 localhost piaware[6641]: multilateration data requested
Apr  7 23:34:19 localhost piaware[6641]: error handling message 'clock\t1554680059\ttype\tmlat_enable\tudp_transport\
54 1154629014' from server: can't read "::adsbLocalPort": no such variable, disconnecting and reconnecting..
Apr  7 23:34:19 localhost piaware[6641]: traceback: can't read "::adsbLocalPort": no such variable
Apr  7 23:34:19 localhost piaware[6641]:     while executing
Apr  7 23:34:19 localhost piaware[6641]: "is_local_receiver $::adsbLocalPort"
Apr  7 23:34:19 localhost piaware[6641]:     (procedure "start_mlat_client" line 15)
Apr  7 23:34:19 localhost piaware[6641]:     invoked from within
Apr  7 23:34:19 localhost piaware[6641]: "start_mlat_client"
Apr  7 23:34:19 localhost piaware[6641]:     (procedure "enable_mlat" line 16)
Apr  7 23:34:19 localhost piaware[6641]: "enable_mlat $row(udp_transport)"
Apr  7 23:34:19 localhost piaware[6641]:     ("mlat_enable" arm line 3)
Apr  7 23:34:19 localhost piaware[6641]: "switch -exact $row(type) {
Apr  7 23:34:19 localhost piaware[6641]: #011#011"mlat_enable" {
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011if {[info exists row(udp_transport)]} {
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011#011enable_mlat $row(udp_transport)
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011} else {
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011#011enable_mla..."
Apr  7 23:34:19 localhost piaware[6641]:     (procedure "::forward_to_mlat_client" line 5)
Apr  7 23:34:19 localhost piaware[6641]: "{*}$mlatCommand row"
Apr  7 23:34:19 localhost piaware[6641]:     ("mlat_*" arm line 3)
Apr  7 23:34:19 localhost piaware[6641]: "switch -glob $row(type) {
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011"login_response" {
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011#011handle_login_response_message row
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011"notice" {
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011#011handle_notice_message row
Apr  7 23:34:19 localhost piaware[6641]: #011#011#011"aliv..."
Apr  7 23:34:19 localhost piaware[6641]:     (object "::adept" method "::fa_adept::AdeptClient::handle_response" body
Apr  7 23:34:19 localhost piaware[6641]: "handle_response response"
Apr  7 23:34:19 localhost piaware[6641]: multilateration data no longer required, disabling mlat client
Apr  7 23:34:19 localhost piaware[6641]: reconnecting in 71 seconds...
Apr  7 23:34:19 localhost piaware[6641]: no ADS-B data program seen listening on port 30005 for 3 seconds, next check
Apr  7 23:34:19 localhost piaware[6641]: UAT support disabled by local configuration setting: uat-receiver-type
Apr  7 23:34:51 localhost piaware[6641]: 0 msgs recv'd from dump1090; 0 msgs sent to FlightAware
Apr  7 23:35:19 localhost piaware[6641]: ADS-B data program 'dump1090-fa' is listening on port 30005, so far so good
Apr  7 23:35:19 localhost piaware[6641]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localho
t 30005 --stdout --lat 43.5xx --lon -79.6xx
Apr  7 23:35:19 localhost piaware[6641]: Started faup1090 (pid 6715) to connect to dump1090-fa
Apr  7 23:35:20 localhost piaware[6641]: piaware received a message from dump1090-fa!
Apr  7 23:35:30 localhost piaware[6641]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Apr  7 23:35:30 localhost piaware[6641]: Connection with adept server at piaware.flightaware.com/1200 established
Apr  7 23:35:30 localhost piaware[6641]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Apr  7 23:35:30 localhost piaware[6641]: FlightAware server certificate validated
Apr  7 23:35:31 localhost piaware[6641]: encrypted session established with FlightAware
Apr  7 23:35:31 localhost piaware[6641]: logged in to FlightAware as user abcd567
Apr  7 23:35:31 localhost piaware[6641]: my feeder ID is xxxxxxxxxxxx
Apr  7 23:35:31 localhost piaware[6641]: site statistics URL: https://flightaware.com/adsb/stats/user/abcd567#stats-6
Apr  7 23:35:31 localhost piaware[6641]: multilateration data requested
Apr  7 23:35:31 localhost piaware[6641]: error handling message 'clock\t1554680131\ttype\tmlat_enable\tudp_transport\
66 3698495259' from server: can't read "::adsbLocalPort": no such variable, disconnecting and reconnecting..
Apr  7 23:35:31 localhost piaware[6641]: traceback: can't read "::adsbLocalPort": no such variable
Apr  7 23:35:31 localhost piaware[6641]:     while executing
Apr  7 23:35:31 localhost piaware[6641]: "is_local_receiver $::adsbLocalPort"
Apr  7 23:35:31 localhost piaware[6641]:     (procedure "start_mlat_client" line 15)
Apr  7 23:35:31 localhost piaware[6641]:     invoked from within
Apr  7 23:35:31 localhost piaware[6641]: "start_mlat_client"
Apr  7 23:35:31 localhost piaware[6641]:     (procedure "enable_mlat" line 16)
Apr  7 23:35:31 localhost piaware[6641]: "enable_mlat $row(udp_transport)"
Apr  7 23:35:31 localhost piaware[6641]:     ("mlat_enable" arm line 3)
Apr  7 23:35:31 localhost piaware[6641]: "switch -exact $row(type) {
Apr  7 23:35:31 localhost piaware[6641]: #011#011"mlat_enable" {
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011if {[info exists row(udp_transport)]} {
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011#011enable_mlat $row(udp_transport)
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011} else {
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011#011enable_mla..."
Apr  7 23:35:31 localhost piaware[6641]:     (procedure "::forward_to_mlat_client" line 5)
Apr  7 23:35:31 localhost piaware[6641]: "{*}$mlatCommand row"
Apr  7 23:35:31 localhost piaware[6641]:     ("mlat_*" arm line 3)
Apr  7 23:35:31 localhost piaware[6641]: "switch -glob $row(type) {
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011"login_response" {
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011#011handle_login_response_message row
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011"notice" {
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011#011handle_notice_message row
Apr  7 23:35:31 localhost piaware[6641]: #011#011#011"aliv..."
Apr  7 23:35:31 localhost piaware[6641]:     (object "::adept" method "::fa_adept::AdeptClient::handle_response" body
Apr  7 23:35:31 localhost piaware[6641]: "handle_response response"
Apr  7 23:35:31 localhost piaware[6641]: multilateration data no longer required, disabling mlat client
Apr  7 23:35:31 localhost piaware[6641]: reconnecting in 55 seconds...
You built 3.7.0, not 3.7.0.1
Thanks for the tip.
Just in time.
I have just now finished reimaging microSd card with Armbian 5.7.5, and have done apt update, apt upgrade, apt dist-upgrade. Was about to start building 3.7.0 again when saw your reply. :slight_smile:
Will now use git checkout v3.7.0.1
As per your advice, now built v3.7.0.1 - THANKS
pi@orangepipc:~/piaware_builder$ apt-cache policy piaware
piaware:
  Installed: 3.7.0.1
  Candidate: 3.7.0.1
  Version table:
 *** 3.7.0.1 100
        100 /var/lib/dpkg/status
pi@orangepipc:~/piaware_builder$ sudo systemctl status piaware -l
   Active: active (running) since Mon 2019-04-08 00:06:50 EDT; 1min 43s ago
 Main PID: 10916 (piaware)
    Tasks: 4 (limit: 4915)
           ├─10916 /usr/bin/piaware -p /run/piaware/piaware.pid -plainlog -statusfile /run/piaware/status.json
           ├─10949 /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhos
           └─10987 /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 43.5xx --lon -79.6xx
Apr 08 00:06:55 orangepipc piaware[10916]: mlat-client(10949): Beast-format results connection with ::1:30104: connection established
Apr 08 00:07:25 orangepipc piaware[10916]: 0 msgs recv'd from dump1090; 0 msgs sent to FlightAware
Apr 08 00:07:54 orangepipc sudo[10985]:  piaware : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/netstat --program --tcp --wide --all --numeric
Apr 08 00:07:54 orangepipc sudo[10985]: pam_unix(sudo:session): session opened for user root by (uid=0)
Apr 08 00:07:54 orangepipc sudo[10985]: pam_unix(sudo:session): session closed for user root
Apr 08 00:07:54 orangepipc piaware[10916]: ADS-B data program 'dump1090-fa' is listening on port 30005, so far so good
Apr 08 00:07:54 orangepipc piaware[10916]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --s
Apr 08 00:07:54 orangepipc piaware[10916]: Started faup1090 (pid 10987) to connect to dump1090-fa
Apr 08 00:07:55 orangepipc piaware[10916]: piaware received a message from dump1090-fa!
Apr 08 00:07:56 orangepipc piaware[10916]: piaware has successfully sent several msgs to FlightAware!
BONUS: Station marker and range rings also now appeared automatically :slight_smile:
dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
pi@orangepipc:~$ apt-cache policy dump978-fa
dump978-fa:
  Installed: 3.7.0.1
  Candidate: 3.7.0.1
  Version table:
 *** 3.7.0.1 100
pi@orangepipc:~$ sudo piaware-config uat-receiver-type sdr
pi@orangepipc:~$ sudo piaware-config uat-sdr-device driver=rtlsdr,serial=00000978
pi@orangepipc:~$ sudo systemctl restart piaware
pi@orangepipc:~$ sudo nano /etc/default/dump978-fa
# dump978-fa configuration
# This is sourced by /usr/share/dump978-fa/start-dump978-fa as a
# shellscript fragment.
# If you are using a PiAware sdcard image, this config file is regenerated
# on boot based on the contents of piaware-config.txt; any changes made to this
# file will be lost.
# dump978-fa won't automatically start unless ENABLED=yes
ENABLED=yes
RECEIVER_OPTIONS="--sdr driver=rtlsdr,serial=00000978  --format CS8"
DECODER_OPTIONS=""
NET_OPTIONS="--raw-port 30978 --json-port 30979"
pi@orangepipc:~$ sudo reboot
pi@orangepipc:~$ sudo systemctl status dump978-fa
● dump978-fa.service - dump978 ADS-B UAT receiver
   Loaded: loaded (/lib/systemd/system/dump978-fa.service; enabled; vendor preset: enabled)
   Active: activating (auto-restart) (Result: exit-code) since Mon 2019-04-08 00:51:22 EDT; 5s ago
  Process: 2133 ExecStart=/usr/share/dump978-fa/start-dump978-fa (code=exited, status=2)
 Main PID: 2133 (code=exited, status=2)
Apr 08 00:51:22 orangepipc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 08 00:51:22 orangepipc systemd[1]: dump978-fa.service: Unit entered failed state.
Apr 08 00:51:22 orangepipc systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
EDIT:
Tried following, but no success :frowning_face:
pi@orangepipc:~$ groups dump978
dump978 : nogroup plugdev
pi@orangepipc:~$ sudo adduser dump978 audio
Adding user `dump978' to group `audio' ...
Adding user dump978 to group audio
Done.
dump978 : nogroup audio plugdev
As always the log is needed :wink:
journalctl -u dump978-fa
pi@orangepipc:~$ sudo journalctl -u dump978-fa
-- Logs begin at Thu 2016-11-03 13:16:42 EDT, end at Mon 2019-04-08 11:01:34 EDT. --
Apr 08 10:58:43 orangepipc systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 08 10:58:43 orangepipc dump978-fa[733]: raw-port: listening for connections on 0.0.0.0:30978
Apr 08 10:58:43 orangepipc dump978-fa[733]: raw-port: listening for connections on [::]:30978
Apr 08 10:58:43 orangepipc dump978-fa[733]: json-port: listening for connections on 0.0.0.0:30979
Apr 08 10:58:43 orangepipc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 08 10:58:43 orangepipc systemd[1]: dump978-fa.service: Unit entered failed state.
Apr 08 10:58:43 orangepipc systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
Apr 08 10:59:29 orangepipc systemd[1]: dump978-fa.service: Service hold-off time over, scheduling restart.
Apr 08 10:59:29 orangepipc systemd[1]: Stopped dump978 ADS-B UAT receiver.
Apr 08 10:59:29 orangepipc systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 08 10:59:29 orangepipc dump978-fa[1677]: raw-port: listening for connections on 0.0.0.0:30978
Apr 08 10:59:29 orangepipc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 08 10:59:29 orangepipc systemd[1]: dump978-fa.service: Unit entered failed state.
Apr 08 10:59:29 orangepipc systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
Apr 08 10:59:59 orangepipc systemd[1]: dump978-fa.service: Service hold-off time over, scheduling restart.
Apr 08 10:59:59 orangepipc systemd[1]: Stopped dump978 ADS-B UAT receiver.
Apr 08 10:59:59 orangepipc systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 08 10:59:59 orangepipc dump978-fa[1702]: raw-port: listening for connections on 0.0.0.0:30978
Apr 08 10:59:59 orangepipc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 08 10:59:59 orangepipc systemd[1]: dump978-fa.service: Unit entered failed state.
Apr 08 10:59:59 orangepipc systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
Apr 08 11:00:29 orangepipc systemd[1]: dump978-fa.service: Service hold-off time over, scheduling restart.
Apr 08 11:00:29 orangepipc systemd[1]: Stopped dump978 ADS-B UAT receiver.
Apr 08 11:00:29 orangepipc systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 08 11:00:29 orangepipc dump978-fa[1731]: raw-port: listening for connections on 0.0.0.0:30978
Apr 08 11:00:29 orangepipc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 08 11:00:29 orangepipc systemd[1]: dump978-fa.service: Unit entered failed state.
Apr 08 11:00:29 orangepipc systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
Apr 08 11:00:59 orangepipc systemd[1]: dump978-fa.service: Service hold-off time over, scheduling restart.
Apr 08 11:00:59 orangepipc systemd[1]: Stopped dump978 ADS-B UAT receiver.
Apr 08 11:00:59 orangepipc systemd[1]: Started dump978 ADS-B UAT receiver.
Apr 08 11:00:59 orangepipc dump978-fa[1752]: raw-port: listening for connections on 0.0.0.0:30978
Apr 08 11:00:59 orangepipc systemd[1]: dump978-fa.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Apr 08 11:00:59 orangepipc systemd[1]: dump978-fa.service: Unit entered failed state.
Apr 08 11:00:59 orangepipc systemd[1]: dump978-fa.service: Failed with result 'exit-code'.
Apr 08 11:01:30 orangepipc systemd[1]: dump978-fa.service: Service hold-off time over, scheduling restart.
pi@orangepipc:~$
Hmm, strange.
Can you run it without the service?
sudo systemctl stop piaware dump978-fa dump1090-fa
sudo /usr/share/dump978-fa/start-dump978-fa
No, it still fails
pi@orangepipc:~$ sudo systemctl stop piaware dump978-fa dump1090-fa
pi@orangepipc:~$ sudo /usr/share/dump978-fa/start-dump978-fa
json-port: listening for connections on [::]:30979
Uncaught exception: Dynamic exception type: std::runtime_error
std::exception::what: SoapySDR::Device::make() no match
ADDITIONAL CHECK:
pi@orangepipc:~$ apt-cache policy libsoapysdr-dev
libsoapysdr-dev:
  Installed: 0.5.4-1
  Candidate: 0.5.4-1
  Version table:
 *** 0.5.4-1 500
        500 http://httpredir.debian.org/debian stretch/main armhf Packages
Wow that’s not a very helpful error message.
How old is the software you run on that thing, maybe the C++ stuff or soapySDR stuff is not recent enough.
Hmm that should be the same as on the RPi.
No clue to be honest.
Can you show the output of rtl_test ?
libsoapysdr-dev: Installed: 0.5.4-1 Candidate: 0.5.4-1
The Armbian image is the latest
pi@orangepipc:~$ uname -a
Linux orangepipc 4.19.20-sunxi #5.75 SMP Sat Feb 9 19:02:47 CET 2019 armv7l GNU/Linux
Before building any packages, I did following:
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
Let’s check rtl_test, maybe the dongle serial doesn’t match?
(Hmm, that shows a different error for me)
(1) The /etc/default/dump978-fa file
ENABLED=yes
DECODER_OPTIONS=""
(2) The piaware-config
pi@orangepipc:~$ sudo piaware-config -show uat-receiver-type
sdr
pi@orangepipc:~$ sudo piaware-config -show uat-sdr-device
(3) The rtl_test -t
pi@orangepipc:~$ rtl_test -t
Found 2 device(s):
  0:  Realtek, RTL2838UHIDIR, SN: 00000978
  1:  Realtek, RTL2832U, SN: 00001090
Using device 0: Generic RTL2832U OEM
Detached kernel driver
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Reattached kernel driver
Ok, do you have the correct module installed?
sudo apt-get install soapysdr-module-rtlsdr
