I decided to upgrade my setup by purchasing the ProStick and accompanying filter, expecting better results than from my standard NooElec dongle. However, the exact opposite occurred; my setup actually experienced a performance drop across the board. I’ve tried various gain settings to no avail, and am coming to y’all for some advice. Graphs are at a 9 day scale.
My guess is the cable is the culprit. Antenna, filter, and dongle are all Flightaware products. Here’s the link to the cable.
Completely unrelated but complicating things nonetheless is my departure to basic training next week. That’s why I’m hoping this performance drop is something that can be easily fixed through the command line. I really do not want to purchase additional hardware.
TP-LINK TL-ANT24PT3 3m/10ft N Male to RP-SMA Male Pigtail Cable
You got the wrong connector. There’s a quick dirty workaround to cut a small piece of coax conductor and shove it in the receptacle turning that into a SMA male.
Have fun at basic! It’ll suck at first but it gets better and more fun…
Would there be another reason that the ProStick would have poor performance at high-temperatures? (worse than just a standard R820T2 chip?
I still need to do some more testing, but I am getting the feeling that its not as good as another R820T2 dongle I have, which has an aluminum case - better heat dissipation.
This is outside, in Phoenix… Like I said, I need to do a controlled test before I can say for sure…
I doubt it’s the crystal; even a 100 degree temperature swing might give you a change of only 30-50ppm which is not much when it comes to ADS-B. It’s quite possible there’s something else that’s unhappy with high temperatures, I’d guess in the RF frontend somewhere.
You can compensate for the crystal offset at a particular temperature via the --ppm parameter. The main thing with TCXO vs uncompensated crystals is just that the offset of a TCXO will not move much with temperature.
