Update link not working (via ssh)
I can’t get or check a update for Flightaware (via ssh).
What is a problem and how i can repair it ?
sudo apt update
Stary:4 http://repo.feed.flightradar24.com flightradar24 InRelease
Ign:1 https://flightaware.com/mirror/raspbian/raspbian bullseye InRelease
Ign:2 https://flightaware.com/adsb/piaware/files/packages bullseye InRelease
Ign:3 https://flightaware.com/mirror/raspberrypi/debian bullseye InRelease
Błąd:5 https://flightaware.com/mirror/raspbian/raspbian bullseye Release
Redirection from https to ‘http://www.flightaware.com/mirror/raspbian/raspbian /dists/bullseye/Release’ is forbidden [IP: 172.64.148.55 443]
Błąd:6 https://flightaware.com/adsb/piaware/files/packages bullseye Release
Redirection from https to ‘http://www.flightaware.com/adsb/piaware/files/packa ges/dists/bullseye/Release’ is forbidden [IP: 172.64.148.55 443]
Błąd:7 https://flightaware.com/mirror/raspberrypi/debian bullseye Release
Redirection from https to ‘http://www.flightaware.com/mirror/raspberrypi/debia n/dists/bullseye/Release’ is forbidden [IP: 172.64.148.55 443]
Czytanie list pakietów… Gotowe
E: The repository ‘http://flightaware.com/mirror/raspbian/raspbian bullseye Rele ase’ no longer has a Release file.
N: Updating from such a repository can’t be done securely, and is therefore disa bled by default.
N: See apt-secure(8) manpage for repository creation and user configuration deta ils.
E: The repository ‘http://flightaware.com/adsb/piaware/files/packages bullseye R elease’ no longer has a Release file.
E: The repository ‘http://flightaware.com/mirror/raspberrypi/debian bullseye Rel ease’ no longer has a Release file.
I was wondering what was going on. My two Pi feeders started throwing update errors on Friday and I thought it might have been due to the large number “oldstable” updates to Bullseye released lately. There have been a flurry of patches due to a myriad of security issues lately.
Hi, still seeing these errors. Was this fixed?
Any word on a solution? I’d like to get my replacement hardware running.
Should be working fine at the moment. What are the errors you see?
When i try to use sudo apt full-upgrade i get the following errors:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following package was automatically installed and is no longer required:
  skyview978
Use 'sudo apt autoremove' to remove it.
The following packages will be upgraded:
  apt apt-transport-https apt-utils avahi-daemon base-files bind9-host ca-certificates cifs-utils cron curl dbus dpkg dpkg-dev e2fslibs e2fsprogs gzip isc-dhcp-client isc-dhcp-common klibc-utils libapt-inst2.0 libapt-pkg5.0 libavahi-common-data libavahi-common3 libavahi-core7
  libbind9-140 libbsd0 libcomerr2 libcurl3 libcurl3-gnutls libdbus-1-3 libdns-export162 libdns162 libdpkg-perl libdw1 libelf1 libexpat1 libflac8 libfreetype6 libfreetype6-dev libgcrypt20 libglib2.0-0 libglib2.0-data libgmp10 libgnutls30 libgssapi-krb5-2 libhogweed4 libicu57
  libidn11 libisc-export160 libisc160 libisccc140 libisccfg140 libjpeg62-turbo libk5crypto3 libklibc libkrb5-3 libkrb5support0 libldap-2.4-2 libldap-common libluajit-5.1-common liblwres141 liblz4-1 liblzma5 libnettle6 libnghttp2-14 libp11-kit0 libpam-systemd libperl5.24
  libpython2.7-minimal libpython2.7-stdlib libpython3.5 libpython3.5-minimal libpython3.5-stdlib libsamplerate0 libsasl2-2 libsasl2-modules libsasl2-modules-db libsndfile1 libsqlite3-0 libss2 libssh2-1 libssl1.0.2 libssl1.1 libsystemd0 libtcl8.6 libudev1 libvorbis0a libvorbisenc2
  libwbclient0 libx11-6 libx11-data libx11-xcb1 libxml2 lighttpd login luajit nfs-common openssl passwd perl perl-base perl-modules-5.24 python-apt-common python2.7 python2.7-minimal python3-apt python3.5 python3.5-minimal rsync rsyslog samba-common skyview978 systemd systemd-sysv
  tar tcl tcl8.6 tzdata udev vim-common vim-tiny xxd xz-utils zlib1g zlib1g-dev
125 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 71.5 MB of archives.
After this operation, 108 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err:1 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf base-files armhf 9.9+rpi1+deb9u13
  404  Not Found
Err:2 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf cron armhf 3.0pl1-128+deb9u2
  404  Not Found
Err:3 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf tar armhf 1.29b-1.1+deb9u1
  404  Not Found
Err:4 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf dpkg armhf 1.18.26
  404  Not Found
Err:5 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf e2fslibs armhf 1.43.4-2+deb9u2
  404  Not Found
Err:6 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf e2fsprogs armhf 1.43.4-2+deb9u2
  404  Not Found
Err:7 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf gzip armhf 1.6-5+deb9u1
  404  Not Found
Err:8 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf login armhf 1:4.4-4.1+deb9u1
  404  Not Found
Err:9 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf libperl5.24 armhf 5.24.1-3+deb9u7
  404  Not Found
Err:10 https://www.flightaware.com/mirror/raspbian/raspbian stretch/main armhf perl armhf 5.24.1-3+deb9u7
  404  Not Found
0% [Working]^C
Cheers!
Luca
We no longer provide piaware packages for Stretch, as upstream support for stretch has ended.
Same with the Raspbian mirror (which is what the errors you see here are from) – upstream no longer provides packages for stretch, so our mirror does not provide them either.
Please consider upgrading to a more recent OS release.
