Tweaks
Glad to know it is now working for you.
I tried to run the script after following the instructions, but keep getting the following error:
sudo: unable to execute ./optimize-gain.py: No such file or directory
I checked the directory and the file is indeed in there, so I am unsure why that error is popping up.
I must be missing something simple, but after deleting and recreating the file several times I still can’t get it to run.
I am using the Piaware SD card image
# first check if file optimize-gain.py is present in the current folder
dir
#if file is not there, cd to the folder where file optimize-gai.py is located
sudo chmod +x optimize-gain.py
sudo ./optimize-gain.py
I was able to get to the site where I have the unit set up and run both those commands. I did verify the file was present (it popped up when I ran dir) before I ran the chmod and executable command, but still had the same error.
I tried creating a blank file, making it executable and running it, and didn’t have any issues, so it must be something with the gain optimization code within the file. I thought I could be missing a package the code needed to run, but the error wouldn’t make any sense if that were the case.
Would it help to re-image the SD card? According to everything I have read, the file should run, but for whatever reason the file system can’t detect the file and keeps displaying the error.
Delete optimize-gain.py file you have already created. Now do this:
#Create a new blank file optimize-gain.py and make it executable
sudo nano optimize-gain.py
#now test blank file by running it
#if no error message appears, then next step is to add code to blank file and run again.
#copy-paste the code in blank file
#save file (Ctrl+o) and close it (Ctrl+x)
#now run the file
Looks like its the code that is affecting the file, because the blank file will run without errors. As soon as I add the code I’ll get the same error as before. I tried deleting the everything after the for loop in the code, and the error was still present.
I experimented with removing certain sections of the code and the closest I could get is removing the first line. When I deleted #!/usr/bin/python2 the program will run with a different set of errors, but since these errors reference lines in the code I think the program is actually being run instead of not being read as is the case when the entire code is present
@ki6fro
I replicated your situation by formatting microSD card and writing Piaware SD card image.
Found solution: Install python.
Please see below for details
pi@piaware:~$ sudo nano optimize-gain.py
#Copy-pasted code from downloaded file "Optimize-Gain-Piaware-SD-Card-Image.docx"
#Saved file (Ctrl+o) and closed it (Ctrl+x)
#Made file "optimize-gain.py" executeable
pi@piaware:~$ sudo chmod +x optimize-gain.py
#Ran "optimize-gain.py", FAILURE
pi@piaware:~$ sudo ./optimize-gain.py
#SOLUTION
pi@piaware:~$ sudo apt-get update
pi@piaware:~$ sudo apt-get install python
test 1 of 5
gain= 49.6 messages= 14817 positions= 1243 planes= 71
gain= 48.0 messages= 17085 positions= 1423 planes= 78
gain= 44.5 messages= 15815 positions= 1394 planes= 85
Thanks abcd567, that fixed it. That call to python at the beginning of the program should have tipped me off. Running the program now and it’s working.
Thanks for the help!
In my Piaware SD Card, I have installed Web Portal / Performance graphs, which installs python also during its installation. That is the reason I did not face any problem when I tried the script.
Only when I erased the existing Piaware SD card image and wrote fresh image, and tried to run optimize-gain.py, I got exactly your problem. I then realized that it is missing python, and when installed python, it started working normally.
Can it display FA’s MLAT calculations after doing this?
BOTH the dump1090-mutability AND dump1090-fa are capable to display FA’s MLAT.
Changing GUI/Skin does NOT prevent, or affect in any way, the display of FA’s MLAT.
So seems just because not MLAT data available in my location :frowning:
It may be because
  1. You have not set your receiver location
    AND/OR
  2. Have not enabled MLAT
Please see following thread and set Receiver Location.
On configure page having ā€œConfigure Locationā€ button, there is also an option to Enable/Disable MLAT. Choose the Enable option
For Beginners - How To Set Receiver Location
Just local MLAT aircraft very few :sweat_smile:
I think there’s something wrong in the docx file.
Character encoding can mess up things. I’m getting the following error:
pi@raspberrypi:~ $ sudo ./optimize-gain.py
File "./optimize-gain.py", line 13
SyntaxError: Non-ASCII character '\xc2' in file ./optimize-gain.py on line 13, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
I’m on mutability & Stretch. I was using Optimize-Gain-dump-mut-on-Raspbian-Jessie.docx
@loplo
The character encoding is ok if opened by Microsoft Word on Windows.
It is bad when opened with LibreOffice on Linux Ubuntu.
I am not sure of Mac, but vaguely remember someone reporting similar problem as yours.
Which computer/OS you use?
I’m using Windows 10, but I don’t have MS Office. I’ve opened the doc with Microsoft Word pad and tried to fix it with notepad++.
In the end I’ve found some of your code on the fr24 forums, and that worked.
At the time I made the thread ā€œTWEAKSā€, it was old format of forum which did not allow posting of scripts. As a result I had to copy scripts to Microsoft Word files (.docx) and uploaded to Dropbox, and gave links to these files.
Later, I came to know .docx format gives problem if opened by any software other than Microsoft Word. I prepared these files in plain text and wanted to change links of dropbox from .docx files to .txt files, but by that time forum formate was changed to new ā€œDiscourseā€, which did not allow editing of old posts.
Since the new forum format allows posting of code, I am posting below codes from all the .docx files here:
There are 4 Scripts below.
Their names describe the installation they will work with.
Select the one which applies to your installation, and copy paste that script to newly created blank file optimize-gain.py
(1) Optimize Gain Script for: Piaware SD Card-Image
#!/usr/bin/python2
import time, socket, subprocess, fileinput, os
measure_duration = 62  #duration of each pass, seconds
ntests = 5  #number of tests
gains = "20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6".split()
#gains = "20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4".split()
#gains = "36.4 38.6 40.2 42.1 44.5 48.0 49.6".split()
gains.reverse()
results = {}
for i in range(ntests):
  print "test", i+1, "of", ntests
  for g in gains:
   if g not in results:
      results[g] = [0,0,{}] #msgs, positions, aircraft
   for line in fileinput.input('/boot/piaware-config.txt', inplace=1):
      if line.startswith('rtlsdr-gain'):
         print 'rtlsdr-gain '+g
      else:
         print line,
   os.system("sudo systemctl restart dump1090-fa")
   time.sleep(2)
   s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
   s.connect(('localhost',30003))
   t = time.time()
   d = ''
   while 1:
      d += s.recv(32)
      if time.time() - t > measure_duration:
         break
   s.close()
   messages = 0
   positions = 0
   planes = {}
   for l in d.split('\n'):
      a = l.split(',')
      messages += 1
      if len(a) > 4:
         if a[1] == '3':
            positions += 1
         planes[a[4]] = 1
   print "gain=",g, "messages=", messages, "positions=", positions, "planes=", len(planes.keys())
   results[g][0] += messages
   results[g][1] += positions
   for hex in planes.keys():
      results[g][2][hex] = 1
print "\n===Totals==="
print "Gain, Messages, Positions, Aircraft"
for g in gains:
   (messages,positions,planes) = results[g]
   print g, messages, positions, len(planes.keys())
(2) Optimize Gain Script for: dump1090-fa on Raspbian
#!/usr/bin/python2
measure_duration = 62  #duration of one pass, seconds
gains.reverse()
results = {}
  for g in gains:
   for line in fileinput.input('/etc/default/dump1090-fa', inplace=1):
      if line.startswith('RECEIVER_OPTIONS'):
         print 'RECEIVER_OPTIONS="--device-index 0  --ppm 0 --gain  ' + g + ' --net-bo-port 30005 --net-sbs-port 30003"'
      else:
         print line,
   time.sleep(2)
   t = time.time()
   d = ''
   while 1:
      d += s.recv(32)
         break
   s.close()
   messages = 0
   positions = 0
   planes = {}
      a = l.split(',')
      messages += 1
      if len(a) > 4:
         if a[1] == '3':
            positions += 1
         planes[a[4]] = 1
for g in gains:
(3) Optimize Gain Script for: dump1090-mutability on Raspbian
#!/usr/bin/python2
#gains = "22.9 25.4 28.0 29.7 32.8 33.8 36.4".split()
gains.reverse()
results = {}
  for g in gains:
   for line in fileinput.input('/etc/default/dump1090-mutability', inplace=1):
      if line.startswith('GAIN'):
         print 'GAIN='+g
      else:
         print line,
   os.system("sudo systemctl restart dump1090-mutability")
   time.sleep(2)
   t = time.time()
   d = ''
   while 1:
      d += s.recv(32)
         break
   s.close()
   messages = 0
   positions = 0
   planes = {}
      a = l.split(',')
      messages += 1
      if len(a) > 4:
         if a[1] == '3':
            positions += 1
         planes[a[4]] = 1
for g in gains:
(4) Optimize Gain Script for: dump1090 (Malcolm-Robb) on Raspbian
#!/usr/bin/python2
measure_duration = 15 #seconds
ntests = 10  #Number of tests
mutability = False    #set to True if you use dump1090-mutability
#gains = "20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6".split()
gains.reverse()
results = {}
  for g in gains:
   if mutability:
       p = subprocess.Popen(('/usr/bin/dump1090-mutability --net --gain '+g+' --oversample --fix --phase-enhance --quiet').split(),shell=False,stdout=subprocess.PIPE, stderr=subprocess.PIPE)
   else:
       p = subprocess.Popen(('/usr/bin/dump1090 --net --gain '+g+' --quiet').split(),shell=False,stdout=subprocess.PIPE, stderr=subprocess.PIPE)
   time.sleep(2)
   t = time.time()
   d = ''
   while 1:
      d += s.recv(32)
         break
   s.close()
   p.terminate()
   messages = 0
   positions = 0
   planes = {}
      a = l.split(',')
      messages += 1
      if len(a) > 4:
         if a[1] == '3':
            positions += 1
         planes[a[4]] = 1
for g in gains:
Awesome, as always!
Thank you!
Ok, just to tie up TWEAK-2: REPLACING TWO-CLOCK MAP (DUMP1090-MUTABILITY) BY SKYVIEW MAP (DUMP1090-FA),
how does one revert back to the two clock map? I can sort of think of how to do it, but if I need to, I don’t want to break anything. I am thinking, it won’t be too hard.
