At the time I made the thread “TWEAKS”, it was old format of forum which did not allow posting of scripts. As a result I had to copy scripts to Microsoft Word files (.docx) and uploaded to Dropbox, and gave links to these files.
Later, I came to know .docx format gives problem if opened by any software other than Microsoft Word. I prepared these files in plain text and wanted to change links of dropbox from .docx files to .txt files, but by that time forum formate was changed to new “Discourse”, which did not allow editing of old posts.
Since the new forum format allows posting of code, I am posting below codes from all the .docx files here:
There are 4 Scripts below.
Their names describe the installation they will work with.
Select the one which applies to your installation, and copy paste that script to newly created blank file optimize-gain.py
(1) Optimize Gain Script for: Piaware SD Card-Image
#!/usr/bin/python2
import time, socket, subprocess, fileinput, os
measure_duration = 62 #duration of each pass, seconds
ntests = 5 #number of tests
gains = "20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6".split()
#gains = "20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4".split()
#gains = "36.4 38.6 40.2 42.1 44.5 48.0 49.6".split()
gains.reverse()
results = {}
for i in range(ntests):
print "test", i+1, "of", ntests
for g in gains:
if g not in results:
results[g] = [0,0,{}] #msgs, positions, aircraft
for line in fileinput.input('/boot/piaware-config.txt', inplace=1):
if line.startswith('rtlsdr-gain'):
print 'rtlsdr-gain '+g
else:
print line,
os.system("sudo systemctl restart dump1090-fa")
time.sleep(2)
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect(('localhost',30003))
t = time.time()
d = ''
while 1:
d += s.recv(32)
if time.time() - t > measure_duration:
break
s.close()
messages = 0
positions = 0
planes = {}
for l in d.split('\n'):
a = l.split(',')
messages += 1
if len(a) > 4:
if a[1] == '3':
positions += 1
planes[a[4]] = 1
print "gain=",g, "messages=", messages, "positions=", positions, "planes=", len(planes.keys())
results[g][0] += messages
results[g][1] += positions
for hex in planes.keys():
results[g][2][hex] = 1
print "\n===Totals==="
print "Gain, Messages, Positions, Aircraft"
for g in gains:
(messages,positions,planes) = results[g]
print g, messages, positions, len(planes.keys())
(2) Optimize Gain Script for: dump1090-fa on Raspbian
#!/usr/bin/python2
measure_duration = 62 #duration of one pass, seconds
gains.reverse()
results = {}
for g in gains:
for line in fileinput.input('/etc/default/dump1090-fa', inplace=1):
if line.startswith('RECEIVER_OPTIONS'):
print 'RECEIVER_OPTIONS="--device-index 0 --ppm 0 --gain ' + g + ' --net-bo-port 30005 --net-sbs-port 30003"'
else:
print line,
time.sleep(2)
t = time.time()
d = ''
while 1:
d += s.recv(32)
break
s.close()
messages = 0
positions = 0
planes = {}
a = l.split(',')
messages += 1
if len(a) > 4:
if a[1] == '3':
positions += 1
planes[a[4]] = 1
for g in gains:
(3) Optimize Gain Script for: dump1090-mutability on Raspbian
#!/usr/bin/python2
#gains = "22.9 25.4 28.0 29.7 32.8 33.8 36.4".split()
gains.reverse()
results = {}
for g in gains:
for line in fileinput.input('/etc/default/dump1090-mutability', inplace=1):
if line.startswith('GAIN'):
print 'GAIN='+g
else:
print line,
os.system("sudo systemctl restart dump1090-mutability")
time.sleep(2)
t = time.time()
d = ''
while 1:
d += s.recv(32)
break
s.close()
messages = 0
positions = 0
planes = {}
a = l.split(',')
messages += 1
if len(a) > 4:
if a[1] == '3':
positions += 1
planes[a[4]] = 1
for g in gains:
(4) Optimize Gain Script for: dump1090 (Malcolm-Robb) on Raspbian
#!/usr/bin/python2
measure_duration = 15 #seconds
ntests = 10 #Number of tests
mutability = False #set to True if you use dump1090-mutability
#gains = "20.7 22.9 25.4 28.0 29.7 32.8 33.8 36.4 37.2 38.6 40.2 42.1 43.4 43.9 44.5 48.0 49.6".split()
gains.reverse()
results = {}
for g in gains:
if mutability:
p = subprocess.Popen(('/usr/bin/dump1090-mutability --net --gain '+g+' --oversample --fix --phase-enhance --quiet').split(),shell=False,stdout=subprocess.PIPE, stderr=subprocess.PIPE)
else:
p = subprocess.Popen(('/usr/bin/dump1090 --net --gain '+g+' --quiet').split(),shell=False,stdout=subprocess.PIPE, stderr=subprocess.PIPE)
time.sleep(2)
t = time.time()
d = ''
while 1:
d += s.recv(32)
break
s.close()
p.terminate()
messages = 0
positions = 0
planes = {}
a = l.split(',')
messages += 1
if len(a) > 4:
if a[1] == '3':
positions += 1
planes[a[4]] = 1
for g in gains:
