XU4 works without problems, I used the airspy web page to set it up with the following command. Actually I just moved from Tinkerboard to XU4Q yesterday
sudo /home/odroid/airspy_adsb -c 127.0.0.1:30104:BEAST -l 30005:BEAST -l 30001:AVR -g 19 -n -p -w 4 &
What problems you have exactly?
The radar is working only with plane finder radar view, normal skyview from Flightaware in my case is not.
If Armbian, failure of lighttpd is the cause of SkyView not showing, The reason is that on reboot, the folder /var/log/lighttpd and file error.log in the folder are deleted, being volatile (i.e. in ram). Lighttpd is unable to re-create these at boot, and fails.
If you run the command sudo systemctl status lighttpd -l, some of the lines in output will indicate this:
opening errorlog ‘/var/log/lighttpd/error.log’ failed: No such file or directory Unit lighttpd.service entered failed state
The remedy is to create the /var/log/lighttpd folder and file error.log at reboot by adding commands to file /etc/rc.local as follows
Edit file rc.local
sudo nano /etc/rc.local
Add following lines at the end of file, just ABOVE exit0
Hmm a bigger problem now, Joe’s or somewhere else install of Flightaware PIaware files error out. So can’t finish a ADSB install, then to add the airspy. However a work around of sorts to test the Airspy. I loaded Ambian bionic ont the airspy and then via their quick install page, installed the necessary files to install a standard ADSB receiver and working perfectly. So until I can get ADSB normal install done, cant advise.
Hey mate, got it working with that fix you have described but with the Airspy setup, they also want to use sudo nano /etc/rc.local with one of their files for auto start up. As you have 4 files added to this rc.local, can you add another totally different file in that dir and where and how do you put it??
/etc/rc.local is a file not a folder, so files cannot be added to it, only commands can be added to it. The 4 files you have mentioned are actually 4 commands, one command per line.
Yes, you can add more commands to file /etc/rc.local. No problem adding different commands, one command per line, just above exit 0.
Ok, thanks, I managed to get it working on install but tried their suggestion about an auto start by adding a “command” lol but it didn’t work. Now have to try the suggestions re the add airspy to existing adsb setup post, but stuck waiting for the Flightaware Piaware github issue to be resolved. At least at the moment, without feeding flightaware, I am comparing the radarcape with the airspy, both on the same sort of antenna, but not at the same height or having the airspy setup near the antenna.
http://IP:30053/map.html
works
odroid@odroid:~$ sudo systemctl status lighttpd -l
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2018-06-08 10:51:18 CEST; 8min ago
Process: 764 ExecStartPre=/usr/sbin/lighttpd -t -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS
Main PID: 817 (lighttpd)
CGroup: /system.slice/lighttpd.service
└─817 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
Jun 08 10:51:17 odroid systemd[1]: Starting Lighttpd Daemon…
Jun 08 10:51:18 odroid lighttpd[764]: Syntax OK
Jun 08 10:51:18 odroid systemd[1]: Started Lighttpd Daemon.
…skipping…
What is in your file /etc/lighttpd/conf-enabled/89-dump1090-fa.conf?
This is what I get:
chip@chip:~$ cat /etc/lighttpd/conf-enabled/89-dump1090-fa.conf
# Allows access to the static files that provide the dump1090 map view,
# and also to the dynamically-generated json parts that contain aircraft
# data and are periodically written by the dump1090 daemon.
alias.url += (
"/dump1090-fa/data/" => "/run/dump1090-fa/",
"/dump1090-fa/" => "/usr/share/dump1090-fa/html/"
# redirect the slash-less URL
url.redirect += (
"^/dump1090-fa$" => "/dump1090-fa/"
# Listen on port 8080 and serve the map there, too.
$SERVER["socket"] == ":8080" {
alias.url += (
"/data/" => "/run/dump1090-fa/",
"/" => "/usr/share/dump1090-fa/html/"
# Add CORS header
server.modules += ( "mod_setenv" )
$HTTP["url"] =~ "^/dump1090-fa/data/.*\.json$" {
setenv.add-response-header = ( "Access-Control-Allow-Origin" => "*" )
do you have a file index.html in your folder /usr/share/dump1090-fa/html?
This is what I see;
chip@chip:~$ ls /usr/share/dump1090-fa/html
config.js flags.js jquery planeObject.js style.css
db formatter.js layers.js registrations.js test
dbloader.js images markers.js script.js upintheair.json
Hello friends,
system is running fine from my point of view.
The latest ADSB Spy exe for windows has the option “DX”, who can tell me what is it doing and how can be that mode activated from the command line to be used on SBC?
I’ve read through this thread trying to get my Airspy mini working with piaware 3.62/stretch both SD image and add on variant with mixed results. I just can’t seem to get everything working together, i.e. feeding to FA together with Mlat and seeing planes etc on skyview.
I know this thread is a couple of years old, but could anyone out there provide an easy to follow script (Dummies guide!) for either SD/add on version which works please.
I have also tried the Airspy version with no success - works on VRS, FA says it’s getting a/c but can’t see anything on skyview to see if Mlat is really running ok.
I saw in one post that I would need to block a port for Mlat in dump1090 for Mlat to work, but unsure how to achieve that either!
Testing the Airspy on its own shows it would improve my results (range and a/c numbers) so would be really great if I could get this up and running.
Well, I have finally got it running on SD card image 3.6.2 after spotting @doughampton comment about using ‘relay’.
Side by side comparison between the Airspy mini and RTL-SDR v3 being fed through filter, amp and mini circuits splitter shows the Airspy providing better results
If you’re on a non-sdcard install then it’s up to you to edit the dump1090-fa (and everything else) config as you see fit. piaware will read the receiver-type setting to work out where to connect to for data, but none of the other setup (running dump1090 in --net-only mode, running beast-splitter, etc) will happen automatically.
I did that. And tried from raspi-config too. It just won’t start… “Server unexpectedly closed network connection”.
I did this because it seems that it’s easier to integrate airspy in a SD card install
I don’t know how to manually setup running dump1090 in --net-only mode, running beast-splitter, etc…
