Step by step how to integrate airspy into existing piaware
[quote=“prog”]
Hi Youssef,
That information definitely helps. I appreciate you taking the time to write it up. As I mentioned before, without any preamp I’m picking up the same number of planes as I was using a non-FA 820T2 dongle with 0.5 ppm deal. I only have a 50 foot cable run (LMR-400) cable run to the attic, but it sounds like I might eek out a few more planes and/or better mlat results with the amp. I’ve already ordered the amp, so I’ll see how that goes. Considering what you said about the Airspy receiver at 1090 mhz, I’m impressed that it’s doing as well as it is.
I’m using “-p -w 4 -g 21” right now, on an RPI3. I’m not using decimation right now on airspy_adsb, and I won’t bother trying it based upon your detailed info above. I’m assuming that once I get the amp installed at the antenna, I am going to want to cut down the gain on the Airspy significantly at that point and not run “-g 21” anymore.
Thanks for your insight. You already know how I feel about your [great] Airspy products!
Mike
