Good afternoon folks,
the reason of this thread is because I’m experiencing problems when I try to execute a HTTP GET call to the FlightXML REST service from my application.
I give you context, my application is being developed with Angular2 (my package.json with the Angular2 versions I use are at the end of this meesage) as a front-end framework with Node.js v7.9.0 as a back-end.
My problems come when using Angular2 HTTP service v2.3.1 I call a GET method to your URL ‘http://flightxml.flightaware.com/json/FlightXML2/FlightInfoEx’
establishing an ‘Authorization’ header with the value of my user and password as seen in next image:
The result of the call can be seen on the next image:
I’ve been looking for a solution for two days thinking that I have made some mistake, but following indications from stackOverflow and Angular2 documentation
I’ve learned that the error received in the response of my GET call is because the server-side doesn’t have enabled the cross-origin resource sharing (CORS) .
(stackoverflow.com/questions/299 … ns-request #See the first answer). This error happens because Angular2 HTTP service follows
the CORS specification sending a preflight request with an OPTIONS method before sending the expected GET method.
Moreover, I’ve tried the same GET call with POSTMAN plugin to ensure that I formed properly the URL and the Authorization header, with success. So, I ask you if
you could tell me that your FlightXML server configuration follows CORS specification, and if the server doesn’t follow it I beg you to add this feature, not only for me but all other potential customers of yours that may develope with Angular2.
For your information, you can follow CORS specification easily with next link: enable-cors.org/server.html
If none of this is possible, can you tell me please where I can see how to configure my Node.js backend to make the calls using restler?
Thanks in advance.
