I am getting this fault when doing a search
$result = $soap->Search("-destination KIAH",10,0);
can someone help
soap_fault Object
[error_message_prefix] =>
[mode] => 1
[level] => 1024
=> NONE
[message] => wrong # args: type InFlightAircraftStruct contains "
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
firstPositionTime int
longitude float
latitude float
groundspeed int
altitude int
heading int
altitudeStatus string
updateType string
altitudeChange string
[userinfo] => stdClass Object
[errorInfo] => stdClass Object
[errorCode] => NONE
[stackTrace] => wrong # args: type InFlightAircraftStruct contains "
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
while executing
“insert_value $d_elt [rpcvar “$itemtype$final” $elt]”
(procedure “insert_value” line 116)
invoked from within
“insert_value $d_elt [rpcvar $ti($eltname) $eltvalue]”
(procedure “SOAP::insert_value” line 175)
invoked from within
“SOAP::insert_value $retnode $result”
(procedure “SOAP::reply” line 17)
invoked from within
“SOAP::reply [dom::DOMImplementation create] $methodNamespace “${methodName}Response” $msg”
[backtrace] => Array
[0] => Array
[file] => C:\PHP\PEAR\SOAP\Fault.php
[line] => 49
[function] => pear_error
[class] => pear_error
[type] => ::
[args] => Array
[0] => wrong # args: type InFlightAircraftStruct contains "
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
[1] => NONE
[2] =>
[3] =>
[4] => stdClass Object
[errorCode] => NONE
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
while executing
invoked from within
invoked from within
invoked from within
[1] => Array
[file] => C:\PHP\PEAR\SOAP\Base.php
[line] => 201
[function] => soap_fault
[class] => soap_fault
[type] => ->
[args] => Array
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
[1] => NONE
[2] =>
[3] => stdClass Object
[errorCode] => NONE
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
while executing
invoked from within
invoked from within
invoked from within
[4] =>
[5] =>
[2] => Array
[file] => C:\PHP\PEAR\SOAP\Client.php
[line] => 608
[function] => _raisesoapfault
[class] => webservice_directflight_directflightsoap
[type] => ->
[args] => Array
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
[1] => stdClass Object
[errorCode] => NONE
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
while executing
invoked from within
invoked from within
invoked from within
[2] =>
[3] => NONE
[3] => Array
[line] => 577
[function] => __decoderesponse
[type] => ->
[args] => Array
[0] => soap_value Object
[value] => Array
[value] => NONE
[name] => faultcode
[type] => string
[namespace] => [schemas.xmlsoap.org/soap/envelope/](http://schemas.xmlsoap.org/soap/envelope/)
[type_namespace] =>
[attributes] => Array
[arrayType] =>
[options] => Array
[nqn] => qname Object
[name] => faultcode
[ns] =>
[tqn] => qname Object
[name] => string
[ns] =>
[namespace] =>
[type_prefix] =>
[1] => soap_value Object
[value] => wrong # args: type InFlightAircraftStruct contains "
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
[name] => faultstring
[type] => string
[namespace] => schemas.xmlsoap.org/soap/envelope/
[type_namespace] =>
[arrayType] =>
[options] => Array
[ns] =>
[name] => string
[ns] =>
[namespace] =>
[type_prefix] =>
[2] => soap_value Object
[value] => Array
[value] => Array
[value] => NONE
[name] => errorCode
[type] => string
[namespace] => urn:FlightAwareSOAP-ErrorInfo
[type_namespace] =>
[arrayType] =>
[options] => Array
[name] => errorCode
[ns] =>
[name] => string
[ns] =>
[namespace] =>
[type_prefix] =>
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
while executing
invoked from within
invoked from within
invoked from within
[name] => stackTrace
[type] => string
[type_namespace] =>
[arrayType] =>
[options] => Array
[ns] =>
[name] => string
[ns] =>
[namespace] =>
[type_prefix] =>
[name] => errorInfo
[type] => Struct
[type_namespace] =>
[arrayType] =>
[options] => Array
[name] => errorInfo
[ns] =>
[name] => Struct
[ns] =>
[namespace] =>
[type_prefix] =>
[name] => detail
[type] => Struct
[type_namespace] =>
[arrayType] =>
[options] => Array
[name] => detail
[ns] =>
[name] => Struct
[ns] =>
[namespace] =>
[type_prefix] =>
[name] => Fault
[type] => Struct
[type_namespace] =>
[arrayType] =>
[options] => Array
[name] => Fault
[ns] =>
[name] => Struct
[ns] =>
[namespace] =>
[type_prefix] =>
[4] => Array
[line] => 312
[function] => __parse
[type] => ->
[args] => Array
[0] =>
NONEwrong # args: type InFlightAircraftStruct contains "
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
"NONEwrong # args: type InFlightAircraftStruct contains "
ident string
prefix string
type string
suffix string
origin string
destination string
timeout string
timestamp int
longitude float
latitude float
groundspeed int
altitude int
heading int
updateType string
while executing
invoked from within
invoked from within
invoked from within
[1] => UTF-8
[2] =>
[5] => Array
[file] => C:\PHP\PEAR\SOAP\WSDL.php(614) : eval()'d code
[line] => 38
[function] => call
[type] => ->
[args] => Array
[0] => Search
[1] => Array
[query] => -destination KIAH
[howMany] => 10
[offset] => 0
[2] => Array
[namespace] => FlightAwareDirectFlight
[soapaction] => FlightAwareDirectFlight
[style] => rpc
[use] => encoded
[6] => Array
[file] => D:\web\pb\flightaware\allairports.php
[line] => 14
[function] => search
[type] => ->
[args] => Array
[0] => -destination KIAH
[1] => 10
[2] => 0
[callback] =>
