My pleasure. Actually thanks should go to @obj who gave me the tip to rebuild the tcl-tls package with the configure option --enable-ssl-fastpath, using latest upstream source code.
Please keep an eye on piaware and after few days post as to how it is going now. Your feedback will help others having similar problem.
on my P2, the usb-wifi dongle died … it’s now got a netgear one from spares box and has been happy for maybe six months.
That said, the usual problem people have is power / or the cable between the power brick and the Pi
Here OP’s problem was NOT power supply as the problem continued even after changing power supply (please see quote from his post below). It was concluded by @obj that this was due to a bug in package tcl-tls. The OP replaced the original tcl-tls package by a rebuild bug-free package, and after that his problem has stopped.
I’ve had two more feeder losses. One was three days ago and another this morning. Here is the last few lines of the log file.
3 13:58:50 piaware piaware[1848]: mlat-client(8515): Server: 0.1 kB/s from server 0.0kB/s TCP to server 1.5kB/s UDP to server
Mar 3 13:58:50 piaware piaware[1848]: mlat-client(8515): Results: 46.6 positions/minute
Mar 3 13:58:50 piaware piaware[1848]: mlat-client(8515): Aircraft: 43 of 116 Mode S, 28 of 31 ADS-B used
Mar 3 14:00:51 piaware piaware[1848]: 5776888 msgs recv’d from dump1090-fa (9916 in last 5m); 5775819 msgs sent to FlightAware
Mar 3 14:05:51 piaware piaware[1848]: 5787894 msgs recv’d from dump1090-fa (11006 in last 5m); 5786825 msgs sent to FlightAware
Mar 3 14:10:51 piaware piaware[1848]: 5795750 msgs recv’d from dump1090-fa (7856 in last 5m); 5794681 msgs sent to FlightAware
Mar 3 14:13:51 piaware piaware[1848]: mlat-client(8515): Receiver status: connected
Mar 3 14:13:51 piaware piaware[1848]: mlat-client(8515): Server status: synchronized with 410 nearby receivers
Mar 3 14:13:51 piaware piaware[1848]: mlat-client(8515): Receiver: 308.6 msg/s received 106.3 msg/s processed (34%)
Mar 3 14:13:51 piaware piaware[1848]: mlat-client(8515): Server: 0.1 kB/s from server 0.0kB/s TCP to server 1.3kB/s UDP to server
Mar 3 14:13:51 piaware piaware[1848]: mlat-client(8515): Results: 53.8 positions/minute
Mar 3 14:13:51 piaware piaware[1848]: mlat-client(8515): Aircraft: 63 of 121 Mode S, 26 of 26 ADS-B used
Mar 3 14:15:51 piaware piaware[1848]: 5804876 msgs recv’d from dump1090-fa (9126 in last 5m); 5803807 msgs sent to FlightAware
Mar 3 14:20:51 piaware piaware[1848]: 5816244 msgs recv’d from dump1090-fa (11368 in last 5m); 5815175 msgs sent to FlightAware
Mar 3 14:25:51 piaware piaware[1848]: 5824611 msgs recv’d from dump1090-fa (8367 in last 5m); 5823542 msgs sent to FlightAware
Mar 3 14:28:51 piaware piaware[1848]: mlat-client(8515): Receiver status: connected
Mar 3 14:28:51 piaware piaware[1848]: mlat-client(8515): Server status: synchronized with 444 nearby receivers
Mar 3 14:28:51 piaware piaware[1848]: mlat-client(8515): Receiver: 329.9 msg/s received 115.4 msg/s processed (35%)
Mar 3 14:28:51 piaware piaware[1848]: mlat-client(8515): Server: 0.1 kB/s from server 0.0kB/s TCP to server 1.4kB/s UDP to server
Mar 3 14:28:51 piaware piaware[1848]: mlat-client(8515): Results: 40.5 positions/minute
Mar 3 14:28:51 piaware piaware[1848]: mlat-client(8515): Aircraft: 48 of 109 Mode S, 36 of 44 ADS-B used
Mar 3 14:30:51 piaware piaware[1848]: 5832420 msgs recv’d from dump1090-fa (7809 in last 5m); 5831351 msgs sent to FlightAware
Mar 3 14:35:51 piaware piaware[1848]: 5843523 msgs recv’d from dump1090-fa (11103 in last 5m); 5842454 msgs sent to FlightAware
Mar 3 14:40:51 piaware piaware[1848]: 5855523 msgs recv’d from dump1090-fa (12000 in last 5m); 5854454 msgs sent to FlightAware
Mar 3 14:43:51 piaware piaware[1848]: mlat-client(8515): Receiver status: connected
Mar 3 14:43:51 piaware piaware[1848]: mlat-client(8515): Server status: synchronized with 458 nearby receivers
Mar 3 14:43:51 piaware piaware[1848]: mlat-client(8515): Receiver: 460.8 msg/s received 151.6 msg/s processed (33%)
Mar 3 14:43:51 piaware piaware[1848]: mlat-client(8515): Server: 0.1 kB/s from server 0.0kB/s TCP to server 1.9kB/s UDP to server
Mar 3 14:43:51 piaware piaware[1848]: mlat-client(8515): Results: 35.1 positions/minute
Mar 3 14:43:51 piaware piaware[1848]: mlat-client(8515): Aircraft: 56 of 128 Mode S, 46 of 56 ADS-B used
Mar 3 14:45:51 piaware piaware[1848]: 5866491 msgs recv’d from dump1090-fa (10968 in last 5m); 5865422 msgs sent to FlightAware
Mar 3 14:50:51 piaware piaware[1848]: 5878202 msgs recv’d from dump1090-fa (11711 in last 5m); 5877133 msgs sent to FlightAware
Mar 3 14:55:51 piaware piaware[1848]: 5887354 msgs recv’d from dump1090-fa (9152 in last 5m); 5886285 msgs sent to FlightAware
Mar 3 14:58:52 piaware piaware[1848]: mlat-client(8515): Receiver status: connected
Mar 3 14:58:52 piaware piaware[1848]: mlat-client(8515): Server status: synchronized with 462 nearby receivers
Mar 3 14:58:52 piaware piaware[1848]: mlat-client(8515): Receiver: 562.0 msg/s received 171.6 msg/s processed (31%)
Mar 3 14:58:52 piaware piaware[1848]: mlat-client(8515): Server: 0.1 kB/s from server 0.0kB/s TCP to server 2.1kB/s UDP to server
Mar 3 14:58:52 piaware piaware[1848]: mlat-client(8515): Results: 18.1 positions/minute
Mar 3 14:58:52 piaware piaware[1848]: mlat-client(8515): Aircraft: 51 of 122 Mode S, 54 of 69 ADS-B used
Mar 3 15:00:51 piaware piaware[1848]: 5899464 msgs recv’d from dump1090-fa (12110 in last 5m); 5898395 msgs sent to FlightAware
Mar 3 15:05:51 piaware piaware[1848]: 5911002 msgs recv’d from dump1090-fa (11538 in last 5m); 5909933 msgs sent to FlightAware
Mar 3 15:10:51 piaware piaware[1848]: 5923911 msgs recv’d from dump1090-fa (12909 in last 5m); 5922842 msgs sent to FlightAware
Mar 3 15:13:52 piaware piaware[1848]: mlat-client(8515): Receiver status: connected
Mar 3 15:13:52 piaware piaware[1848]: mlat-client(8515): Server status: synchronized with 447 nearby receivers
Mar 3 15:13:52 piaware piaware[1848]: mlat-client(8515): Receiver: 695.7 msg/s received 190.6 msg/s processed (27%)
Mar 3 15:13:52 piaware piaware[1848]: mlat-client(8515): Server: 0.1 kB/s from server 0.0kB/s TCP to server 2.1kB/s UDP to server
Mar 3 15:13:52 piaware piaware[1848]: mlat-client(8515): Results: 28.5 positions/minute
Mar 3 15:13:52 piaware piaware[1848]: mlat-client(8515): Aircraft: 86 of 137 Mode S, 65 of 89 ADS-B used
Mar 3 15:15:51 piaware piaware[1848]: 5935428 msgs recv’d from dump1090-fa (11517 in last 5m); 5934359 msgs sent to FlightAware
Mar 3 15:20:51 piaware piaware[1848]: 5948742 msgs recv’d from dump1090-fa (13314 in last 5m); 5947673 msgs sent to FlightAware
Mar 3 15:25:51 piaware piaware[1848]: 5961424 msgs recv’d from dump1090-fa (12682 in last 5m); 5960355 msgs sent to FlightAware
Mar 3 15:28:52 piaware piaware[1848]: mlat-client(8515): Receiver status: connected
Mar 3 15:28:52 piaware piaware[1848]: mlat-client(8515): Server status: synchronized with 460 nearby receivers
Mar 3 15:28:52 piaware piaware[1848]: mlat-client(8515): Receiver: 723.2 msg/s received 205.4 msg/s processed (28%)
Mar 3 15:28:52 piaware piaware[1848]: mlat-client(8515): Server: 0.1 kB/s from server 0.0kB/s TCP to server 2.1kB/s UDP to server
Mar 3 15:28:52 piaware piaware[1848]: mlat-client(8515): Results: 31.0 positions/minute
Mar 3 15:28:52 piaware piaware[1848]: mlat-client(8515): Aircraft: 52 of 136 Mode S, 70 of 89 ADS-B used
Mar 3 15:30:51 piaware piaware[1848]: 5973623 msgs recv’d from dump1090-fa (12199 in last 5m); 5972554 msgs sent to FlightAware
Mar 3 15:34:21 piaware piaware[1848]: Lost connection to adept server at piaware.flightaware.com/1200: server closed connection
Is there a convenient command for downloading logs such as piaware.log to a PC other than using cat and cut & paste the screen? scp doesn’t seem to be cooperating for me.
